Does anyone know?
If I switch between Android phones, will I have to pay for my apps again?
Thanks!
Thanks!
Does anyone know?
Thanks!
I would pay for titanium backup so even protected apps can ne backed up and te installed whenever you want.
Sent from my PC36100 using Tapatalk
I thought Titanium only worked if you were rooted? I wouldn't worry about backing up apps because they stored in the market app. When you log back into the market, go to the downloads section and all your previously downloaded apps will be listed there. Apps you have already paid for will be there as well and you can re-download them for free!
Update: Right in the description on appbrain it says for root only...
titanium
You sir You are correct! I will flog myself later
I don't understand. What is "the market"? I go back in and the app costs $ and it appears that my only choice is to purchase it all over again.
