02-23-2016 05:14 AM
285 ... 7891011 ...
tools
  1. Sam Advanes's Avatar
    My S4 is using Samsung 16G SD Card Class 10 from day 1 and the problem is still there since day 1. But today, the problem seems to be solved when I tested with an old 2G class 4 SD Card which I happened to have for my micro controller project. I will buy and try it with a new 16G class 4 card and see it helps...
    10-31-2013 03:50 AM
  2. NHABD's Avatar
    Purchased my Samsung s4 Oct24 and used my Sandisk 16g class 2 from my old bionic that died. Samsung had no problems recognizing card and my 12 gigs worth of data still intacted. Since than no problems with card read/write. Below is a snap shot of my card.
    I want to get another sd card either a 32g or 64g. Reading all the threads does anyone know if these Samsung card readers can handle a "class 10" ?
    Thank you,
    10-31-2013 10:04 PM
  3. HarryMaroni's Avatar
    Hi i've had exactly the same problem only my phone has now destroyed 3 cards ! two scandisk card 16 and 32 gig and a kingston 16 gig ! tried plugging them into other phones and my mac but no they're well and truly D E A D !
    11-01-2013 01:23 PM
  4. Maggie413's Avatar
    I've had 2 different S4's now and both are card eaters. I've tried a few classes and sizes of cards, and it always happens eventually. This is so disappointing - the phone is stellar, but can't handle something as basic as consistently supporting an SD card?
    11-02-2013 07:46 PM
  5. Stlouis92's Avatar
    Bought a Samsung card ("micro SDXC UHS-I Card" 64GB, Class 10). It's supposedly temperature proof, Xray proof, magnet proof, and is guaranteed 10 years.
    Transferred all my data (30GB+) from my SanDisk 64GB card which was having the unsollicited unmounting issues (transfer : old Card -> PC, PC-> new Card, in both cases using the phone : no issue, but USB might be a bottleneck).
    Up to now, experienced no issue, will update you in a few weeks.
    11-12-2013 02:08 AM
  6. sin13x's Avatar
    So... is there a solution?
    11-13-2013 05:44 AM
  7. bastaci's Avatar
    Hi. Any news? i am suffering the same issue as usual.
    11-18-2013 04:58 AM
  8. Stlouis92's Avatar
    Well, for the moment still no issue seen.
    I cross my fingers.
    rkohlin likes this.
    11-19-2013 02:44 AM
  9. Shmulik Katz's Avatar
    I have littel bit other problem with galaxy s4+ samsung 64gb 10 class card.
    When I insert it to phone I can see all what I transfer from pc..but I can't write on it truth the phone have availability only to read from the card..
    But on other my devices I can write and read.
    So I dont know where is the problem.
    Thanks for any help
    11-19-2013 04:54 AM
  10. Stephanie Chula Garcia's Avatar
    Today all my pictures were gone from my phone....my sd card does not even appear on my phone was it going on with my S4??? Help how do I get pictures back
    11-19-2013 06:08 PM
  11. bastaci's Avatar
    First try to connect your card to PC via sd card reader. If you can see your files, you can transfer to PC. Otherwise, there are recovery programs to do the job. In some cases, phone creates a LOST.DIR folder and put everything in there. However, you will not be able to see anything in that folder at first. There are programs to make those files visible. (Forgot the names of mentioned programs. You can find through forums) Once done, your job is not completed unfortunately. Cause file formats would be different. If you know what kind of files you had, you may try to change file extensions and open it. For example, for jpg files try to name a file .jpg and open. If you can, well...
    Hope this helps.
    11-20-2013 02:42 AM
  12. bastaci's Avatar
    I cross my fingers.
    Please keep us posted then. I am going back and forth, thinking to buy the same card you have.
    Does anyone know if rooting the device and designating the sd card as primary source help to overcome this unmounting issue? I saw somebody made such post in this topic. And, how come some people does not complain with this? I went through tons of forums and many do not seem to have this problem. Maybe we need to learn what setup they have. I am very sorry for not buying LG G2 instead of this crappy phone. Or not buying 32 / 64 gb versions :/
    11-20-2013 02:49 AM
  13. Victor151's Avatar
    I just talked with Samsung technical support about the fact that my SanDisk Ultra 64GB class 10 card only works sometimes on my S4. He said that class 10 is too fast for the phone. He said I should use a Class 4 or 6 and that should work fine. He said it would make no obvious difference in speed. Has anyone else tried this? I'd like to know if it works before buying another card.
    11-22-2013 07:00 PM
  14. Rukbat's Avatar
    Make sure you clean up before you walk on all that stuff he dropped on the floor. That's like saying that your car won't run because the concrete is too high-speed for the car.
    As long as the card is AT LEAST fast enough for the phone, it will operate properly. (I've only been doing this since 1978, so I think I have some small idea of how it works.) If Samsung has designed a phone that won't work with a card that's too fast, they should be run out of the universe on a rail, after being tarred and burned in a star. If they made class 250 SD cards (the class is the access speed), the card should still work just fine with the oldest phone made.
    This is just "bull**** excuse of the day" and it seems that the worse they make the products, the more of it they come up with. Where's a good class action suit when you need one?
    rkohlin likes this.
    11-23-2013 07:03 PM
  15. Stlouis92's Avatar
    Well, at first sight I would react the same way : I don't remember how writing to a Flash memory works (and BTW there are plenty of different species these days), but I don't think there was any sort of handshaking that would put you in a bad state if ever you were to slow as a host.
    11-24-2013 03:09 AM
  16. Rukbat's Avatar
    If you try to write after the card dropped access, you'd be writing to the bit bucket. I suppose it's possible to write to a class 10 card with a controller that can write at speeds so high that the wave function of the electrons damages the Strong Force of the copper in the card, but I'll leave that to the Quantum Chromodynamics guys. (And that would turn a class 4 card into Space Warp Cheese.) I have RAM rated at ms speeds, being written to by CPUs running at GHz speeds, with no problem at all (other than the huge number of wait states generated).
    No, the "Class 10 cards are too fast" is the lie of the day. I wouldn't even pull that on an office manager, let alone people like some who post here and actually know how semiconductors work.
    I can make a couple of wild guesses, though. Sammy may flip modes if you use any card but theirs, and rewrite everything thousands of times. That'll eat cards faster than a starving man eating steak. Or they may use an SSD model to distribute written data if the card is theirs.
    Or they may have just made a crappy phone and they're trying anything to kill the bad publicity. (Which isn't working so well, since there's been so much of it the past few months - every phone they come out with seems to have more bugs than features.)
    Remember the company that came out with a personal computer that pretty much defined the term? That defined it so well that if your computer wasn't compatible with theirs you might as well go into the pencil-selling business? The company that pretty much defined the top operating system in the world? Then got so big that it decided that customers were just expenses to be eliminated? When's the last time they came out with a new PC? (How do you translate "britches" into Korean?)
    11-24-2013 08:43 PM
  17. Stlouis92's Avatar
    Hh ;-)
    Actually MS did not even invent their OS : they stole it. I remember quite well the law suit. The ones with the most expensive lawyers won.
    Back to the cards : it really seems to me that the Samsung card works... Never experienced an unexpected unmounting since I changed.
    This really requires an explanation. It's open source, isn't it ?
    11-25-2013 03:15 AM
  18. Alex Ranah Minang's Avatar
    I have same issue
    Sd card removed unexpectedly and sometimes device reboots itself
    I need to restart device in order to sd card works again
    11-25-2013 09:47 AM
  19. bastaci's Avatar
    Well, i borrowed a 32 gb class 4 micro sd from a friend. I stuffed it with whatever i found, movie, music, e-book... I even installed and played "Bard's Tale" game, which you can choose sd card for installation location. 30 gb is full now. As bullsheit as it seems, card did not unmount, not even once. My previous card, 32 gb class 10 sandisk extreme, would unmount a dozen of times till now. Apart from slower writing speed, i did not notice any adverse effect of class 4 card. Hope my problem is resolved.
    Allow me to add that, this is a major shame on Samsung. As if this is not enough, they don't seem to have any clue, nor they try to solve it. Why? Cause they keep making new phones and don't bother with what is already selling in the market.
    5 days now and still no unmounting. I did LOTS of transfer to/from this card. I even installed several .apk files located in it. I am 90% positive that this issue is related to card speed. I did not try class 6, but class 4 is working just fine. I can still watch HD movies without delay/freezing.
    11-27-2013 01:17 AM
  20. Sapiee Sa's Avatar
    I have same problem.. mine Samsung Galaxy Note 8 & my daughter Samsung Note 3.. Just bought last 2 week & some of pictures can view but cannot do anything (share or edit) & some of it appear corrupted file. Very sad...
    11-27-2013 09:54 AM
  21. mseepman's Avatar
    I'm having the same issues on my S4 from Bell in Canada. I went into the Bell store and they said they never heard of the problem. I have destroyed 3 cards already, one Sandisk, one PNY and one ADATA. 32G, 8G and 16G respectively. Once my phone says unexpected unmounting, then the card is kaput. I can't even format with Win XP...and other devices say "damaged, unable to format"
    11-27-2013 02:13 PM
  22. Rukbat's Avatar
    Oh, I wasn't talking about Windows, or even PC/MS-DOS. A couple of the guys responsible for one of the mainframe systems weren't working for the Big Company when they wrote it. (Of course software gets stolen. Remember Apple suing Microsoft over Windows - that Apple stole from PARC?)
    11-27-2013 10:34 PM
  23. Rukbat's Avatar
    I don't have the problem - I don't have an S4. But I do know San Disk. If someone who has had the problem, and still has the bad San Disk card would write to San Disk, I'm sure they'd be very glad to see if they could a) figure out what went wrong with the card and b) figure out how to prevent it from happening. They're one company that's definitely in the "good guys" column.
    11-27-2013 10:38 PM
  24. Stlouis92's Avatar
    MS DOS, almost 100% copied on Digital Research's CP/M, and initially named Quick & Dirty OS...
    11-28-2013 01:46 AM
  25. rkohlin's Avatar
    Odd question but has anyone, using a Samsung branded card, encountered this issue yet?
    Yes!! I have a small (8gb) Samsung micro SD card that I've had NO issues with for the past 2.5 years, using in my htc EVO.
    I "upgraded" to this pos Samsung Galaxy S IV, & now in just over 5 weeks, I got this message about the SD card being damaged. Thank heavens I'm techie enough to know better than to take Samsung's suggestion message of "Try reformatting" !! How awful! How many people do you suppose did this without realizing they are losing any chance of retrieving their data?!?
    Going to try some of the suggestions here, but, boy, I sure won't have the camera save pics to my card as a default with this phone! (Nothing but issues with this thing! I read in another forum that there are mfging quality issues cuz SG4 got so popular so fast. I might try getting a new phone. The internet access is actually slower (with 2 dual processors!) than it was on my old EVO!! Crazy!
    11-30-2013 10:05 PM
285 ... 7891011 ...
  1. Galaxy S4 SD card issue
    By JamesM1 in forum Samsung Galaxy S4
    Last Post: 10-18-2014, 02:48 PM
  2. Cannot move apps to SD card with Samsung Galaxy S4
    By nkboy9 in forum Samsung Galaxy S4
    Last Post: 11-11-2013, 09:46 AM
  3. Replies: 55
    Last Post: 10-31-2013, 09:41 PM
  4. AT&T Galaxy S3 SD Card issues..
    By joe.kent in forum Samsung Galaxy S3
    Last Post: 03-02-2013, 05:57 PM
  5. SD card issues
    By vbsoulpole in forum Software Development and Hacking
    Last Post: 02-07-2010, 03:04 AM
