picture locations
Ragnar 1
since my bionic upgraded to jelly bean it has been storing pictures internally. How do I set the unit to write picture to the SD card only and how do I move the pictures from internal to the SD Card? Somebody help me before I introduce my phone to my trebuchet.......................
Open your Camera app, tap the menu button and then the Settings icon (the gear icon). There should be a setting there to choose where to store pictures by default.
To move your pictures, you can use any file manager app (either the stock one or a 3rd party one like ES File Explorer) to move your pictures from internal storage (/storage/sdcard0/DCIM/Camera) to your external SD card (/storage/sdcard1/DCIM/Camera).
Moving files using these apps can be a little slow, so you might want to do it using your desktop/laptop. You need to plug it in via USB, make sure the connection settings are set to "USB Mass Storage" or "Disk Drive," then wait for the computer to register the two storage areas as separate drives. Then simply drag and drop like you would on your computer.
slackingfred
