01-19-2017 06:36 AM
64 123
tools
  1. Theking1c3's Avatar
    i have a samsung galaxy mini and it keep saying Error: Couldn't install on USB storage or SD card when im trying to download a app
    the thing is... i delete everything off my phone... wich made a total of 30 Mb and im trying to download an app of 2 Mb
    can anyone help me with that?
    hamza33 and Pruthvirajhegde like this.
    05-13-2013 03:24 PM
  2. Ohyehah's Avatar
    Have the same problem. I'm positive it hasn't got anything to do with memory, and judging by the fact that we both have Samsung mobiles and most likely got these problems around the same time, I'd say Samsung's dropped the ball.
    06-10-2013 08:35 AM
  3. srkmagnus's Avatar
    You can't install the app onto the sd card from Google Play. I suggest going into Menu > System Settings > Applications > Downloaded (sort by file size) and clear the caches for the top apps using the most storage. This should fix your problem.
    Welcome the Android Cetnral, TheKing1c3 & Ohyehah.
    06-10-2013 09:36 AM
  4. Rachel Gill's Avatar
    i get the same msg on my HTC desire x, so its not samsung only :P - if you go to settings-> storage -> unmount SD card
    then install the app
    then mount SD card again.
    it works
    it is a pain that you may potentially have to do this every time the error msg pops up, but its better that it not working at all... right?
    06-14-2013 08:42 AM
  5. jonathan tuason's Avatar
    ol you saying is not working
    07-10-2013 05:45 PM
  6. iFebby's Avatar
    I think this was an issue linked to the kernel at one point on epic 4g touch issues on samsung. Only way I bypassed it was by installing a custom kernel or simply unmounting sdcard before installing apps.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    07-10-2013 09:09 PM
  7. Amr99king's Avatar
    hey,i am Amr khaled 11 years and i am a programmer,if you have this error it means that you uninstalled a lot of apps,so go to google play and click my apps and then bring all,and delete all the uninstalled apps,i hope that helped
    08-15-2013 06:06 PM
  8. meow0526's Avatar
    it works
    ---- thank you so much. this is very helpful. it worked for me. now i can enjoy playing Robinson .
    09-13-2013 08:03 AM
  9. Karan Dhond's Avatar
    Thanks a ton...unmounting the SD card helped installing it...
    10-28-2013 12:53 AM
  10. salu sam's Avatar
    Thanks alot dear
    it's working....thanks alot again
    11-25-2013 01:42 AM
  11. bridget917's Avatar
    Thank you so much for the suggestion on unmounting the SD card...I spent hours trying to download an app with no success and this fixed my problem!
    11-26-2013 06:53 AM
  12. Canameradan's Avatar
    Thx worked great.
    12-19-2013 08:34 AM
  13. Shirley Thomas's Avatar
    hi there i have a samsung S3 if anyone can help me i tryed to install an app from the play store and its always telling me Couldn't install on USB storage or SD card
    12-24-2013 05:08 PM
  14. May Pellam's Avatar
    Genius! Thank you. That solved my problem and I was able to install the app.
    12-27-2013 06:21 AM
  15. mrsmumbles's Avatar
    Did you try the suggestions in posts #3 & #4?
    Sent from my LG870 via Tapatalk 2
    12-27-2013 06:33 AM
  16. Chawoobie's Avatar
    I recently began experiencing the same problem with my Galaxy SIII after upgrading to Android 4.3. Unmounting the SD card, installing the app, then remounting the SD card works, but is not a "solution" I was happy with. I finally arrived at a solution that may work for other phones, as well.
    First, I created a new folder on my laptop, then copied all of the folders and files from my SD card to that new folder. I then unconnected the phone from laptop and reformatted the SD card (yes, it will delete all files and folders on the card, but that is the idea). After reformatting, I copied all the files and folders back to the phone from the laptop. Went to Play.Google and tried installing several apps that had previously been giving me the error message and - NO MORE ERROR MESSAGE!!
    Apparently the SD card needs to be formatted with Android 4.3 OS to work as it should - older OS leads to an incompatibility issue.
    12-31-2013 07:02 AM
  17. Rukbat's Avatar
    Then it's a bug in the update, not in 4.3, because my Note 3 (running 4.3 originally) is using the same card I've been using since Froyo days - and it was formatted in a Froyo phone.
    12-31-2013 03:40 PM
  18. Olivia Radu's Avatar
    I have tried formatting the card, I have tried clearing the cache, I have tried deleting some apps to make more space now I came to realize it is not the a matter of space.. but I cannot figure out what it is and it is now very frustrating. I have a Samsung Galaxy Young Duos GT 6312. So far nothing worked.. still cannot install any app. Please help.
    01-03-2014 03:47 PM
  19. mrsmumbles's Avatar
    What do you need to do, install apps? What are the error messages you get when you try?
    Sent from my Nexus 5 using Tapatalk 2
    01-03-2014 03:52 PM
  20. Olivia Radu's Avatar
    "Insufficient storage available" is the error message I keep on getting.
    I also did this thing… from a mac to the phone… apparently it was supposed to help me install apps on the external card. I was looking now how to undo that… but I can't remember what exactly I did.
    Ufffff…
    01-03-2014 03:58 PM
  21. mrsmumbles's Avatar
    It sounds like you have the dreaded low storage warning. You'll have to back up and delete as much as you can from your phone.
    If you have Android 4.1 or later, usually you can't install apps to the sdcard.
    01-03-2014 04:30 PM
  22. Olivia Radu's Avatar
    thanks. I will backup my phone and then restore to factory settings and start all over again. I have plenty of space. I tried installing an app that takes 2MB… considering that I have more than 700MB free. there's something else not letting me to install. If I had no storage as it claims.. it would install a 2MB app after deleting 2 apps of 7MB and 5MB.
    Anyway… sad and annoying.
    01-03-2014 09:57 PM
  23. kmcdonald03's Avatar
    How do you delete all of the uninstalled apps on the playstore?
    01-06-2014 08:34 AM
  24. karkabeh's Avatar
    01-28-2014 09:38 AM
  25. karkabeh's Avatar
    Go to sittings \storage and unmount your external card then install the application you want
    01-28-2014 09:40 AM
64 123
  1. Installation error Couldn't install on USB storage or SD card
    By zires in forum Barnes & Noble Nook Color
    Last Post: 04-29-2013, 12:17 PM
  2. Replies: 16
    Last Post: 11-13-2012, 04:41 AM
  3. ! Couldn't install on USB or SD card.
    By Thedonkeyshow808 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 03-22-2012, 08:19 PM
  4. save music on internal storage or sd card?
    By LDubs in forum Droid Bionic
    Last Post: 09-19-2011, 10:09 PM
  5. is CM7 faster on internal memory or SD card boot?
    By droodski in forum Barnes & Noble Nook Color
    Last Post: 05-23-2011, 04:26 PM
