Results 1 to 5 of 5
    TMFGO45's Avatar
    Posts
    Global Posts
    80 Global Posts
    Default Prevent getting disconnected while using DATA?
    Right now I am with Verizon, but I am literally 1 thought away from breaking contract and moving to Sprint because of the pricing, and I will happily accept the EVO 4G.
    My question is this, with either Sprint, or Verizon, since they are CDMA, you can only do one or the other, data, or calls/text. If you are using data, say via tethering (i use TETHER on my BB with VZW), when I get a call or text, I immediately lose connection until I ignore the call, or the text is finished processing and it recovers the connection.
    IS IT POSSIBLE, to prevent this situation from occurring while using DATA services? I am sick and tired of being interrupted, and I would love to know how to do this, if possible. Thanks everyone!
  2. #2
    Default
    I think you will not if your on 4g. 3g yes yes and yes
    TMFGO45's Avatar
    Posts
    Global Posts
    80 Global Posts
    Default understandable BUT
    Is there an app or a *code or any method to disable voice and/or text while you are using a data connection? There has to be some way to do this....
  4. #4
    Default
    Quote Originally Posted by TMFGO45 View Post
    Google Voice could probably be set up to not allow any calls through, not sure about texts though.
    crap -> Droid Incredible (4/29/10) -> HTC Thunderbolt (4/9/11) -> Samsung Galaxy Nexus (4/1/2012)
    Samsung Galaxy Tab 10.1 32GB metallic grey (6/17/11)
    My website/blog
    And find me on:
    Google +
    Twitter @kyleNgibb
    gdgt
    AppBrain
    TMFGO45's Avatar
    Posts
    Global Posts
    80 Global Posts
    Default
    Htc thunderbolt. I knew they could do something with the antennas to Make this possible. Too bad I don't want the thunderbolt. Now as long as they start doing this with all phones, the world will be okay.
    Sent from my DROIDX using Tapatalk
