10-03-2014 10:09 AM
65 123
tools
  1. Golfdriver97's Avatar
    I just heard about My Backup Pro. I'd actually used Carbon (now Helium) from the Clockwork Mod people but it wouldn't restore so I restored using the backup I made from my rooting toolkit. Lots of things were missing like images that had been downloaded and screenshots. I had to manually put all that back from the copy I had saved. I even had to reinstall apps manually if I'd purchased them by going to the Google Store and downloading them again, and none of the settings came with them.
    Have you ever restored from iTunes? Is My Backup Pro like that? You don't worry about anything. Everything is put back exactly like it had been. One step and done.
    Sent from the Superuser account on my newly rooted Sprint Galaxy Nexus
    Just read the thread. Congrats on rooting. Now you will see more potential from your phone.
    gnr_2 likes this.
    06-04-2013 02:39 PM
  2. Golfdriver97's Avatar
    When I used MyBackup Pro for apps, it used to restore all data as well so I didn't have to sign in to them or anything. At one point, it stopped working like that but I don't remember what phone that was on.....lol I wanna try it out next time I flash a new ROM.
    Sent from my HOX+ loaded with Elegancia ROM v5.1.0
    Way to go with helping him out. Big thanks to you!
    VDub2174 likes this.
    06-04-2013 02:40 PM
  3. gnr_2's Avatar
    If I ever get to phase 2. LOL
    And VDub has been AWESOME! Here and on PM. That's how I found the correct info on XDA and YouTube.
    06-04-2013 04:30 PM
  4. VDub2174's Avatar
    I get excited when I know how to do things and like helping others out on here
    06-04-2013 04:48 PM
  5. gnr_2's Avatar
    What ROM did you end up with?
    From About phone:
    Android version: 4.2.2
    Kernel version: 3.0.31-cyanogenmod-g64e9296pinky-ghost@cyanogenmod#1
    CyanogenMod version: 10.1-20130411-experimental-toroplus-m3
    Build number: cm_toroplus_userdebug 4.2.2 JDQ39
    06-06-2013 01:09 AM
  6. VDub2174's Avatar
    From About phone:
    Yay!!
    You're gonna be obsessed with flashing ROMs now
    Sent from my HOX+ loaded with Elegancia ROM v5.2.0
    gnr_2 likes this.
    06-06-2013 06:55 AM
  7. gnr_2's Avatar
    Well, I know how to do it really well now because I've flashed this one no less than 8 times. I did a restore from recovery and it brought the system back to where it was before I flashed. So then I flashed it again and restored with only data selected but it wouldn't boot (restore options were system, data, boot), just stayed on the Google unlocked screen. So I restored boot, and it wouldn't go past the CyanogenMod boot screen so I'm back to my stock rom til I can figure it out.
    06-06-2013 01:00 PM
  8. VDub2174's Avatar
    I personally never restore anything through the recovery. I only restore data through an app like MyBackup Pro or ROM Toolbox Pro.
    06-06-2013 01:36 PM
  9. gnr_2's Avatar
    It's weird. Everything is back the way I had it so I'm going to do another My Backup backup and then reinstall the ROM and restore from there. Like I got a second chance.
    06-06-2013 02:06 PM
  10. VDub2174's Avatar
    Oh yeah, when you restore an entire backup from recovery you'll get everything back to the way it was before you flashed anything. It's a magical thing
    06-06-2013 02:42 PM
  11. gnr_2's Avatar
    After the trouble with booting, it made me feel go to know I could just go back and figure it out later. While not fun, it's good to get this level of comfort at the beginning, so it doesn't come as a surprise later after you are used to smooth sailing. Like getting lost in a city you don't know. You figure it out, and then, inevitably, when it happens again, you're like, piece of cake!
    06-06-2013 03:00 PM
  12. VDub2174's Avatar
    I remember the first time something went wrong for me, I freaked out for a little bit but then got myself together......lol
    gnr_2 likes this.
    06-06-2013 07:49 PM
  13. gnr_2's Avatar
    So I'm back to Cm 10.1 but it has updates. Do I need to do all of them - 4? And do I have to wipe everything again to install them? I finally got everything set up again!
    06-07-2013 10:59 AM
  14. VDub2174's Avatar
    Normally, if you're updating the same ROM all you have to wipe is cache and dalvik but that depends on weather or not the dev says to wipe everything or not. Everything will stay as is on your phone that way. You should only have to update to the latest build (not go through all 4).
    You have a link to the ROM you're using?
    06-07-2013 11:59 AM
  15. gnr_2's Avatar
    It's the link you gave me. On the side menu one of the options leads to RC(?) updates - not the nightlies or the Experimental ones. However, they are showing in the settings CyanogenMod has installed on the phone so I don't think I have to go to the link.
    Sent from the Superuser account on my newly rooted Sprint Galaxy Nexus on CM 10.1
    06-07-2013 02:06 PM
  16. VDub2174's Avatar
    When it comes to updates you don't have to apply them all the time. If I remember correctly (someone correct me if I'm wrong), the RC builds are the "final" builds for that version. They may include tweaks, fixes, etc. I don't always update right away if everything is working fine for me
    06-07-2013 07:39 PM
  17. gnr_2's Avatar
    About to try some new ROMs finally. First up BAMF Paradigm, then Eurostank. Woohoo.
    06-25-2013 10:35 AM
  18. VDub2174's Avatar
    I remember when I got my GNex, it came rooted and had BAMF loaded on there already. I liked it
    06-25-2013 10:45 AM
  19. gnr_2's Avatar
    I'm having problems with my system UI so figured it was a good time to factory reset and try a new ROM.
    06-25-2013 12:01 PM
  20. gnr_2's Avatar
    Well, BAMF is about to be outtahere. There don't seem to be options for the dock or app drawer and I can't change my keyboard back to Swift key because the notification isn't showing up. I'm also just getting one notification at a time.
    Question: was it normal for Titanium Backup to ask you to confirm setting permissions for EACH app as it restored them? After 3 I stopped it and restored from MyBackup because of course I'd done 15 different backups again.
    Off to try Xenon, Euroskank and ParanoidAndroid.
    PS can you use any gapps package or do you have to use the one that goes with the ROM? The one at Goo.im is kind of worthless since you just have to install most of the apps from the play store anyway.
    06-25-2013 08:30 PM
  21. VDub2174's Avatar
    Well, BAMF is about to be outtahere. There don't seem to be options for the dock or apo drawer and I can't change my keyboard back to Swift key because the notification isn't showing up. I'm also just getting one notification at a time.
    I remember one of the ROMs I flashed to my GNex did some weird thing with the keyboards. I had to go through the actual keyboard app to set it as default.
    TB did do that to me which is why I downloaded ROM Toolbox Pro. I was tired of approving each app.
    I'm using ParanoidAndroid on my Note 2 now and really like it. The halo))) feature takes some getting used to (if you activate it) and the same goes with teh PIE feature.
    06-25-2013 08:44 PM
  22. gnr_2's Avatar
    I probably would have been willing to look into that and use Apex but the bigger issue was no signal. It also had some weird indicator for the signal where it said "1x". What does that even mean?
    So after flashing Euroskank - not impressed, PA - liked but kept going and then XenonHD, I settled on Xenon. Absolutely *love* it, except can't figure out how to move the Halo thing somewhere not in the way. Set up the whole thing and BOOM - System UI goes out again. After a series of reflashing, rebooting, etc. I have restored back to yesterday. Will reflash Xenon later. It kept telling me there was an update but that the download file was invalid so not sure what that was about. I hadn't even reinstalled any of my other apps so it was something else. Sigh. Will play with it later. Again, glad I had all those problems before or I wouldn't have known to make the TWRP backup because it wasn't part of the instructions I pulled up this time, just you know, data backup stuff.
    06-26-2013 08:34 AM
  23. gnr_2's Avatar
    So back on XenonHD. Love it. This time after flashing, adding Gapps and restoring apps and data, I did a TWRP backup again BEFORE changing the settings. At least I wouldn't have to go back so far if I did something wrong again. The problem seems to have been the charging animation (or the incompatible Gapps package) . Really cool but not stable. I thought it was going to be the boot animation change, but that is working just fine. Did stick with my Apex Launcher, but liking all the other tweaks, especially having my clock centered in the status bar and my blue navigation buttons. Really need to figure out how to move the Halo though as it is *exactly* where I swipe my screen.
    06-27-2013 07:42 PM
  24. VDub2174's Avatar
    Yeah, that halo))) thing is always in the way but I learned to love it.....lol
    06-27-2013 09:04 PM
  25. VDub2174's Avatar
    Still on the hunt for the perfect ROM?
    06-27-2013 09:14 PM
65 123
  1. Trying to Root now...questions about duration
    By bonanzabucks in forum Epic 4G Rooting, ROMs, and Hacks
    Last Post: 10-29-2010, 11:55 AM
  2. New to rooting.. couple questions
    By Kekoh in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 10-11-2010, 11:16 AM
  3. New to rooting.. couple questions
    Last Post: 10-11-2010, 01:20 AM
  4. best way to root + basic questions
    By leingod in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 08-03-2010, 08:42 AM
  5. Replies: 6
    Last Post: 07-22-2010, 08:46 AM
