Android ICS group texting - sends to landlines!
dv8info
54
I have a group that I text to, a sports team, but two of my contacts in the group don't get my messages. They bounce back to me because they are sending to their land phones! Obviously there are multiple phone numbers for these contacts, and the first time this happened I went into the contacts to set the mobile number as default - but that makes no difference. Google Android still tries to send them to the landlines! My phone uses ICS. Can anyone tell me what's going wrong?
Depending on your phone, I remember there being a setting in messages or in contacts to send text messages to mobile number only, or primarily. You could search for a setting like that, I'm not sure what phone you have, and I couldn't find it on my HTC DNA, but I've seen it on previous phones.
The landline numbers that are getting sent to are categorized as "Other" in contacts. I need to give them a different designation. So it would appear that any numbers in contacts labelled as "Other" will be treated as the primary mobile phone. Bizarre behaviour!
That really is odd. I would try playing around with the information in the contact. Good luck.
Sent from my SCH-I905 using Tapatalk 2
kctraci1
