1. Devin Hart's Avatar
    I somehow managed to delete one of the stock notification sounds (galaxy s3 - stock unrooted) i know if you restart the phone it brings it back but I've restarted it 3 times. Any ideas?
    05-25-2013 12:23 AM
  2. Jarnld's Avatar
    Have you looked in a file explorer to see if its really deleted? Or perhaps it got moved by accident. Check out the notifications folder and see if its there, or search the entire device using ES File Explorer or equivalent. Do you remember which sound specifically?
    Check in or around System/media/audio/ if I remember off the top of my head correctly.
    06-02-2013 04:14 AM
  3. Devin Hart's Avatar
    yes, the ringtone was join hangout
    06-12-2013 06:32 PM
  4. grunt0300's Avatar
    Tell me which one it was, and i'll send it to you.
    hangouts_video_call.ogg
    hangouts_message.ogg
    hangout_ringtone.ogg
    PM me with your email address.
    06-12-2013 06:41 PM
  1. Deleting a ringtone?
    By gsontag in forum Motorola Droid
    Last Post: 06-11-2015, 10:52 AM
  2. Deleting ringtone
    By sr2381 in forum Verizon HTC Thunderbolt
    Last Post: 11-29-2011, 10:01 AM
  3. Deleting RIngtones/notification tones
    By owtkast3 in forum Motorola Droid X
    Last Post: 12-27-2010, 04:34 PM
  4. Delete Downloaded Ringtones??!
    By jtriplett005 in forum General Help and How To
    Last Post: 10-01-2010, 02:03 AM
  5. Deleting a ringtone?
    By ICON76 in forum HTC Hero
    Last Post: 11-04-2009, 10:16 AM
