This has frustrated me for a little bit. See the screenshot as a point of reference. I cannot figure out at a glance what the "pins" mean. Sometimes it's all white, straight up and down. Sometimes it's at an angle. Sometimes it's all colored, sometimes the circle is colored but the "pin" is white. I've noticed it in magazines and music. In the screenshot you can see two different "pins" that say "on device". What's the difference??
DOES SOMEBODY HAVE A KEY??
From my HTC One X running ViperXL 3.2
