Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By friedtators
    ahawkua's Avatar
    Banned
    Posts
    Default Will warm or hot weather damage my battery?
    I am so worried about my battery, nothing is wrong with it i just worry a lot. I am afraid to use my phone outside when it's warm or hot because i am afraid that it'll damage my battery. Will warm or hot weather damage my battery? Should i worry about using it outside? Please help lessen my worrying, thanks!
  2. #2
    Default Re: Will warm or hot weather damage my battery?
    Do not leave it in the sun or a hot car. Otherwise it will be OK. It will not last as long in hot temps. Charging in the hot heat is not desirable but for a short period would be OK. Worry too much and the battery will last longer than you.
    Hot is not warm
    B. Diddy likes this.
  3. #3
    gollum18's Avatar
    Posts
    Global Posts
    1,528 Global Posts
    Carrier
    Stock Rooted Mk3
    It would have to be exposed to temperatures 120 degrees fahrenheit and above at extended periods to cause any major damage. Really as long as you don't throw it in a fire you'll be fine
    Sent from my SPH-L710 using Tapatalk 2
  4. #4
    Although keep in mind that in the summer, your car can get pretty frickin hot if left in direct sunlight, easily as high as 120F. Refer to this article:
    http://www.nws.noaa.gov/os/heat/index.shtml#car
    Sent from my DROID RAZR using Android Central Forums
  5. #5
    I'm in AZ and worked where I was unable to bring my phone on site and had to leave it in my car, I also used to have the same worries. I can tell you even though it is not recommended for batteries, I kept multiple phones in 120+ degree cars at least 4 days a week for 10 hours a day and never noticed and significant battery life lose. One thing I should point out though is the fact that I rarely keep a phone longer that a year, after that I have no experience.
    Sent from my SGH-T889 using Android Central Forums
  1. Will this future firmware update damage my rooted NC?
    By Buckmiller in forum Barnes & Noble Nook Color
    Last Post: 03-31-2011, 10:50 AM
  2. Will flashing a ROM or using another kernel improve battery life?
    By Cretz in forum G2 Rooting, ROMs, and Hacks
    Last Post: 02-09-2011, 06:37 PM
  3. Replies: 1
    Last Post: 02-08-2011, 11:09 PM
  4. Replies: 39
    Last Post: 09-26-2010, 08:40 PM
  5. found a battery - any chance it could damage my phone?
    By Lancer033 in forum Motorola Droid
    Last Post: 09-23-2010, 11:52 AM
