A ahawkua Banned Nov 19, 2012 214 0 0 Visit site Jun 4, 2013 #1 on android 2.3.6 will turning animations on use a lot more battery? Would it be noticeable?
F friedtators Well-known member May 27, 2013 824 0 0 Visit site Jun 4, 2013 #2 That depends on the age of the battery. Try it on and next day off and see if you notice. Generally yes you will notice but ease your mind and try it
Golfdriver97 Trusted Member Team Leader Moderator Dec 4, 2012 35,367 113 63 Visit site Jun 4, 2013 #3 ahawkua said: on android 2.3.6 will turning animations on use a lot more battery? Would it be noticeable? Click to expand... Animations on will use more processing, which in turn, uses more of the battery. But, pragmatically, you may not see much of a difference.
