Results 1 to 20 of 20
Like Tree3Likes
  • 1 Post By B. Diddy
  • 1 Post By NotJustAPhone
    Default Completely uninstalling avast
    I uninstalled avast a while back, but I keep getting a notification to upgrade avast anti theft. Does that mean that avast is not completely uninstalled? If so, how can I remove it? If not, what is causing the notification?
    Thanks.
    Sent from my SGH-I747M using Tapatalk 4 Beta
  2. #2
    Default Re: Completely uninstalling avast
    some applications can leave little helpers behind. look in your application list for something off. or is the message a text or an email?
    Nope. It's a notification. I've looked through all of my installed apps and can't find anything related to avast.
  4. #4
    It'd be ironic if Avast used an ad network. Try running Lookout Ad Network Detector.
    Golfdriver97 likes this.
    Thanks for the suggestion. I tried running multiple scans, but it always crashes while scanning the same app. Is there a way to find out which app it's having trouble with?
  6. #6
    Golfdriver97's Avatar
    Posts
    Global Posts
    16,848 Global Posts
    ROM
    Carbon ROM
    Quote Originally Posted by AnAndroidDroid View Post
    I would search through the Application manager. Settings>Application Manager>swipe over to all apps. There may have been something left behind. The other thing that you should be able to do is look through your file explorer, and look for a folder named Avast, and delete that.
    Last resort and I know you won't like it: Factory reset. It will get rid of the Avast problem.
    Phone Timeline
    'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
  7. #7
    Lookout isn't the only ad detector out there. Go to Google Play and search for "ad detector," and you'll find a number of them from reputable names. Try some different ones.
  8. Thread Author  Thread Author    #8
    No trace of avast anywhere. Can't locate it in application manager, no folder named avast through file explorer.
    Tried TrustGo Ad Detector, no sign of avast there either.
    This is so perplexing.
  9. #9
    Posts
    Global Posts
    16,848 Global Posts
    ROM
    Carbon ROM
    Have you restarted since uninstall?
    Sent from my GT-P3113 using Android Central Forums
    Phone Timeline
  10. Thread Author  Thread Author    #10
    Yea I uninstalled it a few weeks ago, so restarted a few times since. The last time I got a notification was a couple of days ago.
  11. #11
    NotJustAPhone's Avatar
    Posts
    Global Posts
    11,780 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Is your phone rooted? As an option, Avast Anti-Theft can be installed as a system app on rooted phones. If that's the case, just uninstalling the app won't remove that part of Avast. You need to reload Avast and use the uninstall option within Avast or delete it from your system folder.
    Sent from my Nexus 4
    Thanked by:
    AnAndroidDroid likes this.
  12. Thread Author  Thread Author    #12
    Phone is not rooted, but regardless I'll try reinstalling avast and uninstalling within the app.
  13. Thread Author  Thread Author    #13
    Reinstalled avast, there is an avast anti theft removal wizard under settings. I have, hopefully, removed it through that, and will uninstall avast as normal. Thanks for the suggestion, hope that's the end of this.
  14. #14
    Posts
    Global Posts
    16,848 Global Posts
    ROM
    Carbon ROM
    Reinstalled avast, there is an avast anti theft removal wizard under settings. I have, hopefully, removed it through that, and will uninstalled avast as normal. Thanks for the suggestion, hope that's the end of this.
    I would send a comolaint to avast. That should have been uninstalled with the rest of the app.
    Phone Timeline
  15. #15
    Personally, I like Lookout. It never bugs me to upgrade to the paid version of anything. It's lightweight, and uses minimal battery compared to Avast.
  16. #16
    Posts
    Global Posts
    11,780 Global Posts
    ROM
    Quote Originally Posted by Golfdriver97 View Post
    I believe that Avast does this intentionally to protect the anti-theft portion from being removed by performing a factory reset. If you install it as a system app, Avast advises you that you have to uninstall using the option inside the app.
  17. Thread Author  Thread Author    #17
    Quote Originally Posted by B. Diddy View Post
    I just went with avast because it was a big name and I preferred its design over avg. In the end, I just got rid of it because I felt, as a lot of others do, that it didn't serve much purpose. Would rather use common sense, which doesn't drain battery or decrease performance, no matter how minimal. As for anti theft I never bothered to set it up.
  18. #18
    That's a reasonable approach for now. The challenge will be knowing when malware technology starts to overcome Android's inherent malware shield, which is the fact that malicious apps can't do anything unless you actually install them.
  19. #19
    delete update manager after selecting all running applications , it belongs to avast
  20. #20
    After reading some of the solutions in the web, they seemed complicated to me (such as rooting the cell phone and searching for a specific file with some tool like Root Explorer). Then, it occurred to me reinstalling and uninstalling Avast again and it worked: Anti-Theft was gone.
  1. Can't the thief simply uninstall the avast or where is my droid applications ?
    By haritha jayathunga in forum Samsung Galaxy S3 I9300
    Last Post: 03-28-2013, 02:11 AM
  2. Uninstall Default Apps
    By ssullivan in forum Motorola Cliq and Dext
    Last Post: 12-04-2012, 05:48 PM
  3. Can I uninstall apps then reinstall them?
    By largeselection in forum Motorola Droid
    Last Post: 10-23-2010, 12:10 PM
  4. look word completion with pysical keyboard!!!!!
    By adriantc in forum Motorola Droid
    Last Post: 11-12-2009, 09:58 PM
  5. How do you uninstall pre loaded applications?
    By sgtoaf in forum HTC Hero
    Last Post: 10-12-2009, 03:02 AM
B
