Results 1 to 4 of 4
    SeeK's Avatar
    Posts
    Global Posts
    296 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    InsertCoin 1.1.1
    Default Volume rocker...
    Is there anyway of getting the volume rocker to only change media volume at all times? I -really- don't want to change my ringtone volume on the go, it's either on full or the phone is in quiet mode. I'm using Ring Guard right now to prevent unwanted reductions in ringtone volume, but I'd like to change this altogether.
  2. #2
    Hugo898699's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Volume rocker...
    i second this. i want something that.makes the volume rocker control the media volume 100% of the time. Anything would help. a solution for nonrooted phones please.
  3. #3
    netshopinc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check out the Volume Rocker app in market. You can quickly change volume profiles and set the media volume (and any other volume) to your preference. It's fully customizable and might be what you're looking for. No root required.
  4. #4
    netshopinc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
