Help Someone Please
Rich32
7
I have a S3 Gt-I9305
I am having problems with restoring my phone as I think there is a system file missing and I have tried nearly everything from flashing a stock Rom for the phone. The screen still won't respond. I am using CWM v5.0.4 I have downloaded CWM 6.0.2.9 which will flash onto my phone. I am not sure if S-Off or S-On could be the reason the phone touch screen won't work and though it might be due to problem with the kernel. This is the kernel I had on the phone before I tried to update/flash a new ROM. kernel version 3.0.31 se.infra@SEP-79#1 SMP PREEMPT Wed 2822:04 KST2012 I can't find that kernel if I search on Google and was wondering if anyone could guide me in the right direction, I can give you the build number if needed.
Sorry, I have no specific answer, but if I may suggest a way to attract more attention for your thread....generic titles like "help" often bring less traffic or less help. It would be good if the thread title gave some indication of what problem you're having. That way it shows up in searches, etc., and might entice someone who knows the answer to pop in. When people just see "help," that could mean a billion things and many will just assume they likely won't know and don't bother to look.
Hahaha!!. Thanks very much you make total sense. I will re post it under a different title.
slackingfred
