I just started prepaid service with Tmobile on my unlocked Samsung Galaxy S2 Skyrocket. I have unlimited min/msg/data. Everything works fine except data. APN settings are correct. Reset APN to default. Data and Roaming are set to on. Wifi is turned off. Tried a hard reset. Called Tmobile and they are unable to assist. What else can I try?
