Galaxy Fame built in FM Transmitter
Altzy
3
Hello all,
i'm using Galaxy Fame and he have built in FM transmitter. Do i need an app to listen music in my car, or there is an option in music player to "activate" that transmitter?
I was searching for that, but no results.
Thanks
Hello all,
Thanks
Welcome to Android Central. I have never had a device with an FM radio so I don't know first hand. But try the instructions here http://help.vodafone.co.uk/system/s...ID=544651&DISPLAY=DEVICE&HANDLERMODE=NOJSPAGE
It is for a different galaxy but maybe the principles are the same
From my Galaxy Note 2 via Tapatalk
Thank you for your reply,
however, i can't see anything related to transmitting a signal, this is tutorial for listening to radio on the phone.
I looked through the Fame manual and I don't see anything about broadcasting an FM signal. where did you see that this device has that ability?
kctraci1
