It is the top left icon on the status bar in the attached screenshot, I cannot find it listed anywhere. I thought it might be GPS, but it isn't and the icon doesn't match. (Galaxy 4S)
Any idea how I can remove it from my notification bar by chance? Since I cannot disable emergency GPS and it is on 100% of the time (in the US), a notification of it running is a bit redundant.
