Often when I open Autodesk Sketchbook Pro for Anroid on my Galaxy note 10.1 and try to import a picture to a layer it says 'this format is not supported yet' but they are just JPEGs and it happens on several pictures so it's not a corrupt file. Other times it will import the same picture.
Also, I now only get two font choices (Sans and Serif) choices where I used to get loads.
Any ideas?
Any ideas?
