S4 lock screen mods?
Mournblade
19
Hi everyone,
I have looked all over, and I can't find any answers - Can you change the font of the lock screen clock? Or can you change the clock out for other clock widgets?
Thanks!:D
Soooo close. Thanks for the info! When I try to add other widgets to the lock screen, i am limited to what is available, and none of the options (that I can see) will let me change the font.
1) enable multiple widgets in settings
2) download a clock widget apps (eg. Clock jb which im using)
3)swipe down your clock widget on lockscreen and move it to a trash on the top of your screen
You will have an option to add a widget or anything
Then choose the clock or widget you want
Hope this helps :)
kctraci1
