Results 1 to 4 of 4
    SJC#CB's Avatar
    Posts
    Global Posts
    2 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Itunes and Adroid
    I am trying to find a way to sync iTunes with a Samsung Galaxy S4. My desktop currently run Ubuntu 12.04, but I do not want to use the desktop for syncing if possible.
    TIA
    Steve
  2. #2
    EvilMonkey's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Itunes and Adroid
    Welcome to the forums. Not overly familiar with Ubuntu, but maybe look at Doubletwist.
  3. #3
    charkzilla20's Avatar
    Posts
    Global Posts
    100 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You could possibly upload your music to your Google Play Music account and allow your device to stream the music from the app.
  4. #4
    garublador's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You'll have to use some sort of PC if you want to sync iTunes with your phone.
    Most cases involve installing additional software on your PC that works with an app on your phone. Chances are you'll have to use a method similar to the one you use to get iTunes to work on Ubuntu to get the new software to work as well. Who knows how big of a pain that will turn out to be. Otherwise you just copy your iTunes library to your phone manually.
    The next thing you can do, as charkzilla20 suggested is to change music managers. The only issue with the Google one is that you can only "pin" (download to your phone without having to stream) songs to internal storage. That means you can't use the SD card so your space is probably pretty limited. I've only searched briefly, but I can't find a really good way to sync your Android phone to Rhythmbox or Banshee. There was one thread about doing it over WiFi in Banshee but it didn't look like a very full featured sync.
    No matter what you'll have to remove DRM from any songs you purchased through iTunes before April of 2009.
  1. Synching ITunes and GooglePlay Music
    By UncleLes in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-08-2013, 02:06 PM
  2. itunes and Atrix
    By goodbyeiphone in forum AT&T ATRIX
    Last Post: 07-30-2011, 10:50 PM
  3. iTunes and Evo 3D
    By socca1157 in forum HTC EVO 3D
    Last Post: 06-27-2011, 10:56 AM
  4. Podcasts, iTunes and adding them to Beyond Pod
    By mikedaub in forum Android Apps
    Last Post: 05-26-2011, 02:11 PM
  5. Adroid and email
    By mrich70 in forum Android Apps
    Last Post: 05-24-2010, 08:31 PM
