Hi Guys,
I'm new here so hello, my problem is the following:
I followed an XDA developer guide to root my tab, I followed it to the letter and its messed up my tab. The tab now won't boot to the OS, instead going to the screen where you can only use the buttons to navigate - with a hat symbol in the middle? It keep saying it cant mount anything. I've managed to boot up using the command ADH reboot bootloader in command prompt, but thats all I can do with it. I have a recovery image and also the twrp.blob in the adk folder but when I use the flash command in command prompt on my PC while connected to the tab it says "[waiting for device]" then nothing happens. I have unlocked the tab, and have debugging mode on. Ive installed all the SDk stuff, and the computer recognises the device when connected to USB but nothing seems to be working.
PLease please help
thanks
PLease please help
thanks
