Does anyone know if there is any way to post emoticons on instagram???
Thanks for that. I do have the keyboard stock however it does not work on instagram unfortunately.
Thanks for responding. I currently am using android 4.1.2 and I still cannot respond with emoticons using stock Google keyboard. I also downloaded handcent SMS which allows me to use emoji when I text but not for instagram.You need Android 4.0+ to use that keyboard. There might be other keyboards in the Play Store either Emoji support for your devices OS.
Sent from my SPH-D710 using Tapatalk 2
