Results 1 to 2 of 2
    Smile Uberoid wifi problem
    Hi, I hope this is in the right forum, if not apologies. I have just flashed A13 Uberoid v1.0 onto my A13 tab and I have 2 problems. One is that the entire screen seems to be offset slightly to the right but more importantly every time I try to switch on wifi it keeps going back to off again before I have a chance to even put the password for my router in. Does anyone know if there is a fix for this? All advice will be gratefully received and thanks in advance for any help.
    EDIT: I have now flashed a different rom and this has solved the problem
  2. #2
    Default Re: Uberoid wifi problem
    I'm having the exact same problem. May I ask which was the rom you installed that solved your problem?
  1. Wifi problem.
    By joec32033 in forum Verizon Droid Incredible
    Last Post: 09-13-2010, 08:02 PM
  2. wifi problems
    By Sere81 in forum Verizon Droid Incredible
    Last Post: 07-21-2010, 05:49 PM
  3. Nexus running 2.2 wifi problems!!!
    By DVNO in forum Google / HTC Nexus One
    Last Post: 06-05-2010, 01:28 AM
  4. Droid WiFi Problems
    By jlgraham in forum Motorola Droid
    Last Post: 03-30-2010, 04:02 PM
  5. Wifi Problems on Eris
    By twizler3 in forum HTC Droid Eris
    Last Post: 12-10-2009, 07:54 PM
