Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By gollum18
    Default Does the phone prioritize using wifi over cellular data when both are available?
    I have just an all around question. When you have your WiFi and your 4G on and you are connected to WIFI which one will ur phone use first? Or is your phone actually using both WiFi and 4G? I always thought it was WiFi then 4G if WiFi is unavailable.
    Sent from my DROID RAZR using Android Central Forums
  2. #2
    Default Re: Just a general ?
    If, you're connected to wifi, that's what your phone will use. If not, it'll drop back to your cellular data.
    So its not pulling using both if they are both on? Correct?
    Sent from my GT-P7510 using AC Forums mobile app
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    6,777 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Quote Originally Posted by Ms Charli View Post
    It's not pulling from both.
    Sent from my SPH-D710 using Tapatalk 2
  5. #5
    Correct. Just pulling from wifi.
    Clarified! thanks guys!
  7. #7
    I use wifi when ever I am in a wifi zone then I turn off mobile data.
    iPad iPhone 4,4s,5,5s Nexus 7 (2013) Galaxy S4 Nexus 5 and so much more.....
  8. Thread Author  Thread Author    #8
    Are you turning off mobile data because u want to or because it saves battery etc...? Why turn it off if its not effecting anything?
    Sent from my Kindle Fire using Android Central Forums
  9. #9
    Mobile data uses more battery.
  10. #10
    Sizzers's Avatar
    Posts
    Global Posts
    316 Global Posts
    Quote Originally Posted by neonworm View Post
    If I donít need data that means I donít need 3G (4Gís a bit behind over here!), so as well as switching off data I also switch off 3G and use 2G instead.
    Makes a big difference battery wise.
    Putting out fire with gasoline
  11. #11
    gollum18's Avatar
    Posts
    Global Posts
    1,532 Global Posts
    ROM
    Stock Rooted Mk3
    As stated previously, if your phone is within range of your wifi's signal it will use that instead of your 4g as it is much more efficient to do so. Now when you fall out of wifi range your phone will aitomatically default back to 4g.
    Sprint GS3 Running TN's Msg and Chubbs
    Current Laptop - Samsung Ativ 4 Book, Ivy Bridge I7 @ 2.00GHz per Core, 8GB DDR3 Ram, Intel HD 4000, 750GB SATA
    Please don't thank me unless I have helped you in some way, if you like my post then click like not thanks.
    Check out my github @ https://github.com/gollum18 or My Android Applications @ http://lrdev.net76.net
  12. #12
    gollum18's Avatar
    Posts
    Global Posts
    1,532 Global Posts
    ROM
    Stock Rooted Mk3
    It especially uses more batgery if there is little to no signal at all. A phone will kill itself trying to find or maintain a dead/weak signal.
    FishenFool likes this.
  13. #13
    Now correct me if I am wrong but while on wifi there is no need to turn off mobile data because you are not using it, you are using wifi. You will not save battery life.
  14. #14
    gollum18's Avatar
    Posts
    Global Posts
    1,532 Global Posts
    ROM
    Stock Rooted Mk3
    Quote Originally Posted by TgeekB View Post
    The radio chip will still remain on but it won't transmit unless you send/receive mms as they can't be sent or received over wifi.
  15. #15
    You may want to check to see how your carrier handles MMS. IIRC, many times picture and video messages will be sent over mobile data rather than WiFi so if you turn off your mobile data you won't be able to send or receive them. I don't think there will be very much, if any, noticeable battery savings from turning off your mobile data unless you're in an area with bad reception.
  1. snapchat just loads blank screen
    By Philip Adderley in forum HP Touchpad
    Last Post: 08-22-2013, 12:05 AM
  2. Just ordered HTC One Google Edition
    By mdandashly in forum Google Nexus 4
    Last Post: 07-13-2013, 04:48 PM
  3. Just got a Kindle Fire HD 8.9 and had some questions on rooting.
    By Metal Chaos in forum Amazon Kindle Fire HD
    Last Post: 07-12-2013, 01:30 AM
  4. The new: "It just works".
    By jimbo1mcm in forum Samsung Galaxy S4
    Last Post: 07-03-2013, 10:51 AM
  5. Just stumbled upon this 8bit live wallppaper.
    By Eion in forum Wallpapers, Ringtones, and Themes
    Last Post: 07-01-2013, 03:36 PM
B
