Results 1 to 5 of 5
    Default Samsung i9305 no sim problem
    hi m i have a problem with my phone where one of my friend did something on my phone and now it does not recognize any sim cards. i have tried to factory reset but nothing changed.
    i read some posts that you have commented and i went to download mode it says
    I also tried to do what a site indicated me to do which were Steps to install Android 4.1.2 XXBMD5 Jelly Bean on Samsung Galaxy S3 LTE GT-I9305
    and also
    Steps to root Samsung Galaxy S3 LTE GT-I9305 on Android 4.1.2 XXBMD5 Jelly Bean
    ODIN MODE
    PRODUCT NAME: GT-I9305
    CUSTOM BINARY DOWNLOAD: Yes (3 counts)
    CURRENT BINARY: SAMSUNG OFFICIAL
    SYSTEM STATUS: Custom
    also does not allow me to update the software after the factory reset
    here is a screenshot
    can you please help me.
    many thanks
    PS- the sim card works with other phones. i am from uk
    Attached Thumbnails Attached Thumbnails Samsung i9305 no sim problem-untitled-1.jpg
  2. #2
    Scott Kenyon's Avatar
    Posts
    Global Posts
    2,204 Global Posts
    ROM
    MoDaCo Switch Beta 8
    Default Re: Samsung i9305 no sim problem
    What, exactly, did your friend do? Was it software related?
  3. #3
    I have the same problem and I don`t know how to fix it after an odin operation failed...it showed me an menu in downliading mode and I've tried to do the operation manualy in that menu and after reboot it doezn`t recognize any sim card...I`ve tried difernt ones but nothing...and also inserted those sim cards in other phone and it works. Can anibody help me please? Thank you
  4. #4
    Hi there, I'm facing the same problem.
    I'm from Brazil, but I bought the I9305 in Hong Kong last year (2013). On early 2014 some software update became available and I accepted the installation, the android got updated to the 4.3 version and now I just can't use the phone with my own SIM card, also all the SIM cards that I've tried is not working as well. Does anybody now if samsung would give support for a non rooted version since the problem appears only after their own update?
    Best Regards
    Fabio G. Martins
  5. #5
    Rukbat's Avatar
    Posts
    ROM
    AreaROM 3.0 or CM7.0.1
    To the OP:
    1) Rooting has nothing to do with the SIM.
    2) Go to your carrier's service center (or ask at the local store where the service center is) and be honest - that a friend did something to your phone and now it won't recognize the SIM. They can fix it - even if they have to reflash the ROM and burn a new SIM. Then you'll have to decide whether recovering the cost from your friend is worth the friendship.
    3) Rooted phones usually won't OTA update. They're considered modified.
    To the others:
    The 4.3 update had some bugs. The carrier may be able to reflash to an earlier ROM. If not, and the phone isn't still under warranty, you may have a legal battle on your hands. They (whoever sent out the update to your phone) broke the phone but won't accept liability.
  1. Samsung i9305 no sim problem
    By slim1092 in forum Sprint Galaxy S3
    Last Post: 07-10-2013, 01:03 PM
  2. Start Problems - black monitor
    By Pimpuzzo in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 07-09-2013, 08:39 AM
  3. Problems???
    By thrashm in forum HTC First
    Last Post: 07-09-2013, 07:16 AM
  4. Play Audio & Video on TV from Samsung Android Mobile S3 - S4
    By meashish in forum General Help and How To
    Last Post: 07-09-2013, 01:48 AM
  5. missing quick setting (newts nos m7)
    By johnowoss in forum Verizon Droid DNA
    Last Post: 07-08-2013, 09:39 PM
B
