1. SpiralBorg's Avatar
    Closed
    07-10-2013 03:31 AM
  2. VDub2174's Avatar
    *ALSO - Say if I got a US based ROM for a Australian device, would it work flawlessly?
    Any help would be nice,
    Thanks.
    US ROMs on International devices never play nice. You'll either get a boot loop or a bricked device
    07-10-2013 07:21 AM
  3. srkmagnus's Avatar
    How about the Nexus 4? Seeing as their is a singular version, the stock ROM for that will work on any N4 (from any country)?
    Any way, its alright. From now on, Ill just keep it to stock recovery: And just flash CWM when there`s a custom ROM I favour.
    That way, I can get OTA updates easily, and not hassle all over XDA for a deodexed ROM, or a specific-country ROM.
    thanks for your help
    If devices have different radios then you sill start to have problems or possibly a bricked device. It's always advised that you only install ROMs intented for your specific device to not have issues. I have heard of people installing ROMs meant for International devices onto US ones as long as the radios are not changed, but I don't recommend it.
    Regarding the official OTA updates, you can unroot back to stock and receive OTA updates. However, it should be noted that on most devices you may no longer be able to re-root right away if the manufacturer patched the root exploit. If you are using the N4 then there won't be an issue since that device is designed to be rooted easily with the stock firmware. You might want to sit tight and wait for a Developer to release a stock, rooted version of the update for flashing through CWM to not deal with the unrooting process.
    07-10-2013 09:29 AM
  4. Paul627g's Avatar
    ^^ This was very important...
    Its not the ROM or OS itself that causes a brick its the radio firmware that causes the brick in most cases. So that is why we always stress flash only official/unofficial software that is intended for your exact device, carrier, country and/or region.
    07-10-2013 09:37 AM
  1. Preventing contacts from syncing with Google
    By OFFS in forum Google Nexus 4
    Last Post: 02-20-2016, 10:28 PM
  2. Word definition app integrated with all text fields.
    By A Mandaliya in forum Samsung Galaxy S4 Active
    Last Post: 02-25-2014, 02:47 AM
  3. Life with the one 14 Days in..
    By Bigbill01 in forum HTC One M7
    Last Post: 07-11-2013, 07:30 PM
  4. Help!!! Red triangle with exlcamation
    By Levi Alvarado in forum Samsung Galaxy S4 Google Edition
    Last Post: 07-10-2013, 01:47 AM
  5. Maps update removes icon from app drawer
    By thegov in forum HTC One M7
    Last Post: 07-10-2013, 12:15 AM
