1. mpec82's Avatar
    I've seen it's possible to create a switch (two separate groups of action on the same tag) so for example I can have a tag on the door of my house that with the first pass activate wifi and with the second deactivate it. My question is waht happens if between the the two passes I use a second tag (a simple one or one with a switch)? When I pass again on the first tag, what action will be executed (the enter or the exit task). I hope it's clear enough to get an answer. Thanks in advance for your time/help.
    07-10-2013 06:23 AM
  2. alicechong7789's Avatar
    I tried this using NFC task Launcher.
    Tag 1 has Task 1: turn on wifi, Task 2: Turn off wifi.
    Tag 2: open up camera.
    Here is what happened: Tag 1/Task1 --> Tag2 --> Tag1Task2. So somehow the phone or the App is still remembering to switch between task 1 and task 2 even though there was a different tag that came in between.
    07-11-2013 10:57 AM
  1. Help!!! Red triangle of doom
    By Levi Alvarado in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 07-11-2013, 02:26 AM
  2. I'm glad my choice to switch to Nexus has paid off
    By Rule9 in forum Google Nexus 4
    Last Post: 07-10-2013, 08:00 PM
  3. Help!!! Red triangle with exlcamation
    By Levi Alvarado in forum Samsung Galaxy S4 Google Edition
    Last Post: 07-10-2013, 01:47 AM
  4. Help, I can't access the file system on my nexus 7
    By Bryon15 in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 07-10-2013, 01:23 AM
  5. Replies: 5
    Last Post: 07-09-2013, 10:52 PM
