I find the camera sound very annoying on my phone, and even if it's on silent, it plays the camera sound. This is how to remove the camera sound.
1. Using a file explorer, I recommend es file explorer or root explorer, go to /system/media/audio/ui and there you will see 2 camera files.
2. Copy and Paste them into your sd card, then delete them from /system/media/audio/ui
3. This will keep your phone from making the camera noise.
