Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By tfurrows
  • 1 Post By prsiim
  • 1 Post By prsiim
    Jamesgillaspy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default I have an LG Optimus Zone Vs410PP need help rooting
    I've truer just about everything but manually trying to.code a.root please help '4me what am I.doing.wrong???
  2. #2
    silentsgame's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: I have an LG Optimus Zone Vs410PP need help rooting
    DID U EVER get your vs410 rooted? because im having trouble and need help.
  3. #3
    tfurrows's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It was fairly simple, if you know a little bit about what is going on. Here's what I did (Under Win7, already had android SDK installed):
    1. Locate and download SuperOneClick v1.7 "rageagainstthecage" version (some antivirus may see it as a threat, from what I understand it is not)
    2. Locate and download the Universal ADB USB Driver (https://github.com/koush/UniversalAdbDriver)
    3. Install the Universal ADB driver, then browse to the install folder and edit the INF file. Add the following lines in the LG section. You may need to double-check your phone, but these were the IDs for my Optimus Zone. Save the file (elevated perms may be necessary):
    %LG% = USB_Install, USB\VID_1004&PID_6244
    %LG% = USB_Install, USB\VID_1004&PID_6244&MI_04
    4. Connect-up your LG, put it in debug mode. Check in "Devices and Printers" to see if the device installed properly. If it did not (yellow bang) then you will need to right-click, choose the first yellow bang (hardware ID in the properties should match the above), and click "Change Settings" then "Update Driver".
    5. If you have to manually update the driver, you may have to go about it the long way. I had to click "Browse my computer..." then "Let me pick from a list..." then "Have disk..." before browsing all the way to the Universal ADB folder, plus I had to click "OK" through several warnings.
    6. Once the ADB USB drivers are installed, turn off debugging on your Optimus Zone. Leave the USB connected.
    7. Start SuperOneClick 1.7, choose "rageagainstthecage" in the top right, and click "root" on the left.
    8. When "Waiting for device" shows up, turn on debugging on the Optimus Zone. Let SuperOneClick do its thing (takes a few minutes)
    9. Once everything looks done run the test. Now, disconnect and power cycle your Optimus Zone
    10. SuperUser may not work; simply update it from the Play store... the new version works like a charm
    And that was all I had to do.... Good luck!
    Tannus likes this.
  4. #4
    makeAstain's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hi. im new to the site. just wanted to say i got this to work by not turning off debugging.
  5. #5
    prsiim's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Crossing my fingers if u can can u show me some pictures
    dandan10 likes this.
  6. #6
    prsiim's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So I go into "UniversalAdbDriver/usb_driver/android_winusb.inf" and then add (%LG% = USB_Install, USB\VID_1004&PID_[DEVICE ID]
    %LG% = USB_Install, USB\VID_1004&PID_[DEVICE ID]&MI_04) how do I find my device ID?
    Tannus likes this.
  7. #7
    tfurrows's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Finding the device ID depends on your operating system. If you're in a recent version of Windows, you can just connect the device, then locate the non-working device driver in "Devices & Printers", right-click on it, select "Properties", go the the Hardware tab, select it in the list and click the Properties button, go to the Details tab and choose "Hardware IDs" property. They will appear in the box on that dialog.
    Tannus likes this.
  8. #8
    couponmo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is my first time doing this, and I need help. When I get to installing the driver, I'm told that the driver is not compatible with Windows for x64. Any thoughts? Thank you!
  9. #9
    prsiim's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have windows 8 x64 and it works
  10. #10
    Judy Dogan1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've done every thing just as describe. About to throw phone against the wall. Keeps saying su binary not found.
    Such test failed.
  11. #11
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I wish u would help me figure this out. Judydogan@Hotmail.com only if u are willing to help. Thanx
  12. #12
    erik broussard's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you change the Device ID to your actual device's ID? I haven't attempted it yet but I got the same error before
  13. #13
    Mike Jones27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    very easy compared to some exploits ive dealt with... TY for info
  14. #14
    rootseeker's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I found poot-debug.apk at xda forums that rooted mine without computer. I had to try about ten times but it finally worked. Remove the battety between every retry of the app then install root checker from google store to check status between retries. Good luck!
    LG Optimus Zone vs410pp now rooted.
  15. #15
    johnny Mnemonic's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did anyone manage to solve the driver install problem I need the com port driver
  16. #16
    Tatiana Taylor's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    how do i change the double click settings on a LG VS415PP?
  17. #17
    TwistedWolf's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by makeAstain View Post
  1. HELP...Bluetooth works but won't display info on paired device
    By gunner1954 in forum Samsung Galaxy S4
    Last Post: 02-26-2014, 10:19 PM
  2. Google Play Music All Access vs. Root/ROM
    By TJH132 in forum Verizon Galaxy Nexus
    Last Post: 10-01-2013, 10:10 PM
  3. Is this a good choice for an engineering student?
    By William Heymann in forum Samsung Galaxy Note 8.0
    Last Post: 07-22-2013, 10:11 PM
  4. I have a question about esn and programming on a galaxy note 2 or s3?
    By Joe Stentiford in forum General Help and How To
    Last Post: 07-21-2013, 01:13 AM
  5. Dead android problem HELP
    By hiiiiiiiqueso in forum General News & Discussion
    Last Post: 07-20-2013, 08:54 PM
