Could anyone please help me to locate External USB folder.
I have Samsung Galaxy Note10.1. As soon as USB is connected, a message appears in bottom right corner:"USB connector connected", then disappears. I try to locate the sub-folder in the Storage Folder, but it's not there. I don't know where it is.
I go to Setting and reset it to factory default, then it works. But when I unplug USB stick and plug it in again, it doesn't work. How come it doesn't read USB stick?
I'm sure someone out there can help me to solve this problem.
Many thanks
Hien
Many thanks
Hien
