Results 1 to 2 of 2
    Exclamation Micro SD card problem
    I have a PNY 16GB HC Micro SD card (in virgin mobile samsung reverb). I've had it for about seven months and the other day i dropped my phone (in otter box) and then it said it couldn't read my sd card so i pulled it and blew out the slot and on the card and put it back. It then said "SD card blank or unsupported data, so i put it in the adapter and put it in my computer. it detected it and i started to move my pictures and apps over to a file. in the middle of this it said "data transfer interrupted, please insert disk into drive" so i pulled it out and put it back. it did the same thing two more times and now it won't detect it at all. i don't wanna loose all the stuff on it so can anyone help me recover the data? thanks.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,731 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Micro SD card problem
    Quote Originally Posted by coltont27 View Post
    Did you properly eject the card from the phone and the PC? It is also possible that the drop may be the source of your issues. As for recovering the data, I am not sure you can.
  1. Blank SD Card Issue
    By minime1327 in forum Samsung Galaxy Note 2
    Last Post: 06-29-2015, 12:32 PM
  2. Best memory card+class for SG Note 2 ?
    By Somdk in forum Samsung Galaxy Note 2
    Last Post: 12-09-2013, 10:10 AM
  3. Would you have bought the S4 if Samsung didn't include SD card slots?
    By Kiersten_Kress in forum Samsung Galaxy S4
    Last Post: 07-30-2013, 03:25 PM
  4. SIM Security Problem
    By gozirra in forum Verizon Galaxy S3
    Last Post: 07-24-2013, 12:52 AM
  5. Nexus 7 Torrent problems,
    By jrfinn33 in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-23-2013, 04:53 PM
