1. dytkd's Avatar
    Can someone please explain to me how that works, and how do i find out which devices are compatible with it? I heard that is available on new n7, but i don't exactly know what it means.
    Thanks
    07-24-2013 12:40 PM
  2. Scott Kenyon's Avatar
    You get a charging mat for your desk/nightstand whatever which plugs into the wall. When you lay your device down on the mat the device will begin to charge. Is that the explanation you're looking for? If not, there's a great podcast called Brainstuff that explains this in detail quite briefly. I'm not capable of doing a better job, so here:
    How can an electric toothbrush recharge its batteries? - BrainStuff - CastRoller
    07-24-2013 12:48 PM
  3. dytkd's Avatar
    That sounded pretty clear to me...thank you
    07-24-2013 12:52 PM
  4. mbtechfella79's Avatar
    you need special equipment but its relatively easy and pretty awesome. Does anyone have any experience with these for a long period of time? I'd like to know how the battery life holds up over time
    07-24-2013 01:26 PM
  1. Need game suggestions for mothers tablet
    By lucasbuck in forum Samsung Galaxy Note 10.1
    Last Post: 10-04-2014, 05:00 AM
  2. Replies: 3
    Last Post: 09-19-2013, 08:00 PM
  3. Advice needed before I root
    By fixit5561 in forum LG Optimus S
    Last Post: 07-27-2013, 03:36 PM
