Results 1 to 14 of 14
Like Tree3Likes
  • 1 Post By Mooncatt
  • 1 Post By Jutta Carl
    Jutta Carl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Tablet charging/usb hub?
    Greetings;
    Probably a dumb question, however is it possible to charge and connect(at the same time) a USB hub for mouse and USB keyboard using an OTG cable? My new tablet has only a micro USB port for both charging and data. I know everyone dislikes tablets with dedicated charging ports, but I miss it. Thanks.
    Regards
  2. Best Answer
    It should because that's the reason to chose a powered over non-powered hubs. Though you do need to make sure it has a high enough power rating, preferably a rating per port. I haven't used one for this purpose, but I know they are recommended if running multiple devices that pull all of their power via USB like this and external hard drives. Non powered hubs are only good for small things like mice, keyboards, controllers, and webcams. If the hub isn't strong enough, you could see the charge level drop on the tablet. Worse case is you burn out the hub's power supply by working it to hard.
  3. #2
    Golfdriver97's Avatar
    Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Tablet charging/usb hub?
    Quote Originally Posted by Jutta Carl View Post
    Greetings;
    Regards
    It should charge, but it would also depend on the power output of the hub.
    Sent from a SlimROM S3.
  4. #3
    Mooncatt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I also hate relying on USB for charging, so you're not fully alone.
    What I would consider is using a powered USB hub just to be on the safe side. It would have its own dedicated wall power connection instead of relying on the computer to power several devices from the one port split up.
    Golfdriver97 likes this.
  5. Thread Author  Thread Author    #4
    Jutta Carl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks Golfdriver97 and Mooncatt, will the powered USB hub charge the tablet while using the mouse and keyboard; I know, another dumb question!
    Cheers
  6. #5
    Mooncatt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  7. Thread Author  Thread Author    #6
    Jutta Carl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks again Mooncatt, I finally understand, you've been a great help.
    Cheers
  8. #7
    srkmagnus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Cheers
    Let us know which hub you decide on getting...I never considered one before but that doesn't mean I won't in the near future.
  9. Thread Author  Thread Author    #8
    Jutta Carl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Greetings srkmagnus;
    I'm going with a Pluggable 7port High Speed. USB 2.0 Hub. With 3A Power adapter from Amazon for $19.95. I hope it will have enough power to charge the tablet as well as power a USB keyboard and mouse.
    Regards
  10. Thread Author  Thread Author    #9
    Jutta Carl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Recieved the Plugable powered usb hub from amazon today,and am now using it with my new Lenovo S6000 tablet. I'm using a usb keyboard, mouse, and the 3A hub is charging the tablet as well. I'm a happy camper as I can now do more work on the tablet with no battery drain!
    Regards
    srkmagnus likes this.
  11. Thread Author  Thread Author    #10
    Jutta Carl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry, it seems I celebrated too soon. Using the powered hub and OTG cable allows me use of the mouse and keyboard, however tablet will not charge at the same time. I believe the tablet will not allow charging while using usb items. I suspect my next tablet purchase will be one with a dedicated charging port like my wife's Toshiba Excite.
    Regard
    Carl in Florida
  12. #11
    srkmagnus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Thanks for the follow up, it's much appreciate.
    Sent from my SPH-D710 using Tapatalk 2
  13. #12
    villuj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Perhaps the solution mentioned in here would help to get the tab charging and using usb at the same time: http://www.androidtablets.net/forum/...tml#post286336
  14. #13
    razorfishsol's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    USB HUB fast charger tablet ipod ipad phone USB BITCOIN
    Razorfish Solutions manufacturers
    USB HUB fast charger 19 Port USB Hub with Integral power supply and Steel/Aluminum case
    This is a 19 port hub With an integral power supply capable of
    reliably supplying MORE that 500mA per port without overheating or becoming a fire hazard.
    16 Front facing Standard A USB ports 3 Side facing Standard A 1 Master hub connection
    Standard B for connection to Computing Equipment or other hubs Fully fused internally via multiple poly-fuse resettable fuses both on each individual port and on the main power feed to the Ports.
    Unlike may of the cheaper USB ports that only implement links at 1.0 12mb/s speeds
    (but state they are 'compatible' with USB 2.0)
    this is a professional FULL 480 Mb/s port that complies and implements the full 2.0 USB standard,
    it may also be used to connect to generic USB 1.0 equipment.
    www.razorfishsolutions.com.hk
  15. #14
    Rukbat's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    There are OTG adapters that have charging ports, so you can use a USB device (or probably a hub) and charge the phone/tab at the same time. They're only a few dollars more than the non-powering ones. Look on Amazon.
  1. Acer a100 won't charge
    By chieflet in forum Acer Iconia A100
    Last Post: 10-21-2014, 12:33 AM
  2. How to enable usb debugging?
    By vlee in forum Google Nexus 4
    Last Post: 04-22-2014, 11:17 PM
  3. Htc one charging issue>>>>>>>
    By Jay Lamps in forum HTC One M7
    Last Post: 08-31-2013, 03:34 PM
  4. Replies: 5
    Last Post: 08-05-2013, 08:06 PM
  5. Galaxy S3 Connected via USB Shuts Down PC
    By nicc_furee in forum General Help and How To
    Last Post: 07-28-2013, 12:22 PM
