1. sandhu89's Avatar
    imy friend me a tablet .its running on android 2.3.1 , i want to update it to ics or jellybean ...plzzzzzz help me to identify this tablet .plzzz give me links of suitable custom roms ... i rooted it with the help of gingerbreak.apk , its rooted now but i dont have cmw recovery . can i update it to ics version plzzzzzz help me , . plzzz send me suitable cmw recovery and ics rom so i can update it plzzzz help me i dont know what i do ..plzz help ..here is some other info also
    product name - BB02
    CPU Chipsets - Cortex A8 core (1.0GHZ)
    SDRMA - 512MB DDR3
    Flash Memory - 4GB
    Touch Panel - Capacitive touch[BOX][/BOX]
    Display - 7inch Led
    Camera - front , CMOS , 2.0 Megapixel
    Gravity induction - 3 axis
    adobe flash player 10.3 is working
    Connection - Usb Type A2.0 high speed port ,
    Micro USB 2.0 port
    Battery Li-Polymer 3.7v . 3000mAh
    Model number - MID
    Kernel version - 2.6.32.27
    koffu@ubuntu # 230
    Build number gingerbread_v2.10.00
    eng.koffu.20120302.185444
    Attached Thumbnails need help plzzz plzzzz help me-shot_000010.jpg   need help plzzz plzzzz help me-shot_000008.jpg   need help plzzz plzzzz help me-shot_000001.jpg   need help plzzz plzzzz help me-20130725_065032.jpg   need help plzzz plzzzz help me-20130725_064942.jpg
    need help plzzz plzzzz help me-shot_000006.jpg   need help plzzz plzzzz help me-shot_000006.png   need help plzzz plzzzz help me-shot_000009.jpg
    07-29-2013 12:47 AM
  2. Shadowriver's Avatar
    First of all this is Honeycomb not Gingerbread 2nd if this is offical software and software it self does not know what model of hardware it is on it only means it's chinese crap, avoid buying those if you don't want to have updating problems, because it very hard to find any.
    You might have better luck searching in xda-developers, if you wont find anything there you won't find anything (atleast in english sites)
    07-29-2013 02:54 PM
  1. Help - Trouble connecting to Amped Wireless Extender
    By jr461 in forum Google Chromecast
    Last Post: 10-19-2013, 05:59 PM
  2. Replies: 3
    Last Post: 08-07-2013, 09:00 AM
  3. Split screen help
    By MagicMike Kelley in forum Samsung Galaxy S4
    Last Post: 07-29-2013, 08:08 PM
  4. Help: My phone won't send special characters anymore!
    By ezelllohar in forum General Help and How To
    Last Post: 07-29-2013, 03:00 PM
  5. Making an s3 case...need your help
    By editionfws in forum The Android Central Lounge
    Last Post: 07-28-2013, 11:38 PM
