I am having trouble with receiving txts. I seem to be able to send them but can't receive them. I have a warning saying that the text memory is full. There is also a message saying the phone storage space is full. ????
Sounds like this is a problem with the phone. Call your provider and ask their advice. This isn't a common problem, so you might need to switch the phone out or reboot to factory settings.
what phone do you have, and how much memory does it say you have left over in the storage settings. you may need to delete some apps that you dont really use/want anymore
+1 to the last three posts. For some reason, when you run low on space, Android decides to stop receiving texts. Makes sense, since they take up space, but unfortunately these texts just disappear into thin air.
