Results 1 to 11 of 11
    Default has anyone filled up their phone's memory yet?
    I'm just wondering, has anyone filled their phone's memory yet? I mean like both internal and external (microSD) memory. I've yet to have heard anyone do that yet I've maxed out my iPod Touch's memory a few times.
    For anyone that has had this happen, where do you place that extra data? Do you use a cloud service? carry an extra microSD card? set up a network? I'd like to know out of curiosity.
  2. #2
    SeeK's Avatar
    Posts
    Global Posts
    296 Global Posts
    ROM
    InsertCoin 1.1.1
    Default
    Quote Originally Posted by Spartan745 View Post
    I have, but my SD card is only 4GB. I'm planning on getting a 16GB or maybe even a 32GB one when I get my next paycheck. As more and more apps are starting to include A2SD support, I don't think internal memory space will be much less of a problem soon.
  3. #3
    dmnall's Avatar
    Posts
    Global Posts
    630 Global Posts
    ROM
    Latest AOKP!
    Default
    I still have not even filled up my 4 GB Card came close when I transferred a few anime videos to the card running my old bb bold 9000 but on the captivate, I have not even come close. I am planning on a 32 GB card once class 6 are available.
    Cheers,
    Charlie
    Samsung Captivate - RIP 10-6-2011 Currently: Samsung Galaxy S2 i777 - Rooted, Sim Unlocked and soon to be debloated
  4. #4
    Default
    Why does the owners manual for my EVO state that I have to use the stock card? What happens if I use a reputable supermarket? Does it void the warranty?
  5. #5
    moosc's Avatar
    Grand Master Moosc
    Posts
    Global Posts
    5,019 Global Posts
    ROM
    AKOP M4 old geezer theme
    Default
    Doubt u can fill up my X. I have 8gb internal for apps. And i have a 32gb that has 12gb used.
  6. #6
    mikestorm's Avatar
    Posts
    Global Posts
    980 Global Posts
    ROM
    AOKP
    Default
    Gads no. 16GB card with only 7GB or so used. There's a mail widget but out there that exponentially eats memory and triggers a 'device memory low' error message. I'm thinking that's all that happens.
  7. #7
    Karnaj's Avatar
    Posts
    ROM
    Android 2.3.2 GPA10
    Default Re: has anyone filled up their phone's memory yet?
    @dmc1068 Nothing bad will happen too your phone SD Cards (Secure Digital) there has been a industry standard developed, which means that they are made and operate in the same way. I personally have never heard of Warranties being voided by using reputable thrid party cards. Too the subject at hand yes I have filled up my 14 gb sd card already.
    Karnaj
    Sent from my Droid using Tapatalk
  8. #8
    Ive filled up my sd card with music, ive been using my droid x as my music player. My internal memory still has lots of room thought.
    Sent from my DROIDX using Tapatalk
  9. #9
    dtboos's Avatar
    Posts
    Global Posts
    826 Global Posts
    Default
    Internal memory? Yes. Well, I've gotten the low memory warning a bunch of times, so moved a few things to my SD card, but without doing so I'd be out of memory and have a few missing apps.
    I'm using an N1 so my internal memory is sorely lacking, and I was only able to move as much to my SD card as I did through hacking the phone.
  10. Thread Author  Thread Author    #10
    Default
    Well yeah it'll be almost impossible to fill up internal memory with just apps but I mean including music, videos, gaming roms, etc.
  11. #11
    SeeK's Avatar
    Posts
    Global Posts
    296 Global Posts
    ROM
    InsertCoin 1.1.1
    Default
    Depends on the size of your internal memory. :P Mine only leaves 147MB to the user, rest is taken by operating system and such. I filled my SD card with PSX images and music, mainly. Filled it up quite rapidly.
