1. cocosiy's Avatar
    Help! Need to find my deleted data from Android!
    I deleted SMS, Contacts from my Android phone by mistake, they are very important! Is there any way to get it back? Your help will be appreciated. Thanks!
    08-08-2013 12:39 AM
  2. srkmagnus's Avatar
    Unfortunately SMS can't be retrieved if you didn't make a backup with an app. Contacts can be retrieved simply by logging back into your Google Account associated with your device - if you had this sync'd then contacts will load automatically once you sign back in.
    Somdk likes this.
    08-08-2013 01:16 AM
  3. Geekymonkey's Avatar
    01-21-2014 06:03 PM
  4. Rukbat's Avatar
    SMS Backup+ saves them as xml files. They're readable as-is, even if you don't restore them. You just have to ignore the xml tags. But if you restore them you get back what you backed up.
    As far as contacts go, make sure that all your contacts are entered as Account contacts. (When you enter one, you have a choice of Account, Phone and, if you have a SIM card, SIM.) That way, any phone logged into that gmail account has those contacts. There's nothing "to do" - it just works that way (as long as you have sync contacts enabled for that email account.)
    01-21-2014 11:03 PM
  5. Kody888's Avatar
    I ever forgot to backup my phone before resetting it to factory settings, which resulted in losing all contacts and messages. Then I downloaded the Android Phone Geeker and recovered all my contacts and messages.
    08-14-2014 11:21 PM
  6. Tenoty's Avatar
    I have a recommendation for you -- "MobiKin Doctor for Android",I use it to recover my Samsung phone data.including contacts,text message,photos.etc,It is work well, this is a comprehensive software.Simple, just a few will be able to quickly restore your contacts,Hope this helps!
    10-20-2014 04:49 AM
  7. gone down south's Avatar
    Can you see your Gmail contacts on the desktop computer?
    10-31-2014 10:46 AM
  8. Rukbat's Avatar
    The only contacts that get synced to Google are those entered as Google contacts, not Phone, Device or SIM contacts. Go to Google Contacts and you'll see which contacts you synced. Anything not there isn't coming back to the computer. (Which is why all your contacts should be entered as Google contacts, and why Google should change the default from Device to Google - most people end up entering all their contacts as Device contacts, then lose them all on a reset.)
    To answer your final question, "how can i recover my contacts again?", you can't "recover" anything you haven't already backed up somewhere. (Which is why you should back up at least all your app data and texts at least once a week. And any contacts that aren't Google contacts, although I don't know why you'd want to enter them as anything else.)
    Any data not backed up to at least 2 independent destinations is data you don't need. That was true back when IBM first started making programmable computers (the 1950s) and it's always going to be true. The most valuable part of any computer is the data on it.
    10-31-2014 12:51 PM
  9. Sheryl Gardner1's Avatar
    12-26-2014 08:08 AM
  10. noahrobert's Avatar
    The contacts are just invisible in database of device files system. Actually, they are still stored on the Android phone just like deleted files on PC, which means they are totally recoverable. As far as I know, there are a few Android Data Recovery apps that are fully capable of recovering lost data on Android device including contacts, text messages and more. I like FonePaw Android Data Recovery - Mobile Solution Expert.
    07-08-2015 08:52 AM
  1. [How-To] Make a thread
    By jaboop in forum General Help and How To
    Last Post: 02-13-2014, 12:06 PM
  2. See the apps needing update on Web. Google Play doesn't show anymore.
    By LucidLunacy in forum General Help and How To
    Last Post: 08-11-2013, 12:05 AM
  3. Android Device Manager Dont Work For Me
    By kilo720 in forum T-Mobile Galaxy S III
    Last Post: 08-10-2013, 11:42 PM
