1. ItsChaii_28's Avatar
    listen up guys ! i need your help, basically i rooted my htc one S for the first time which went fine... i then tried to flash PAC-MAN rom onto it which also wasnt a problem. the problem was i didnt have GAPPS (i didnt know i needed it at the time) when i tried to install it, it never worked so i was told to wipe my phone and do it all again but now my computer is telling me to format my phone doesnt that mean it'll delete everything ? how am i supposed to put on a new os and gapps ? please help !!!!!!!
    08-12-2013 10:36 AM
  2. aandrew610's Avatar
    You just flash gapps through your custom recovery like you did the ROM
    sent from my galaxy s4
    08-12-2013 10:40 AM
  3. ItsChaii_28's Avatar
    i cant put gapps on to my phone because my computer is telling me to format it
    08-12-2013 10:42 AM
  4. aandrew610's Avatar
    Did you make a backup of your phone before you flashed the ROM
    08-12-2013 10:44 AM
  5. metle_geek's Avatar
    exactly you just need to get the gapps package it will be gapps.zip put it in a folder where you know where its at on the sd go to flash.zip file in your recovery use the file explorer to find the file you put it in and simply flash it but be careful get the gapps for your rom or you will have serious trouble
    Sent from my HTC One X+ using AC Forums mobile app
    08-12-2013 10:45 AM
  6. ItsChaii_28's Avatar
    i dont think you understand i cant get into my phone, here is the error message "g:\ is not accessible the volume does not contain a recognized file system. please make sure that all required file system drivers are loaded and that the volume is not corrupted"
    08-12-2013 10:58 AM
  7. iHackPro's Avatar
    Can you download it on your phone using GooManager? Look for the, I'm assuming it's Android 4.2.2, gapps-2013301 package.
    08-12-2013 11:06 AM
  8. ItsChaii_28's Avatar
    i cant use my phone i dont have an OS since i was told to wipe it
    08-12-2013 11:07 AM
  9. iHackPro's Avatar
    Who told you to wipe it without making a backup first?
    Sounds like you'll have to flash a stock ROM through the Android SDK, which is beyond my knowledge.
    08-12-2013 12:17 PM
  10. aandrew610's Avatar
    That's what you'll have to do is find the stock ROM flash it.then reroot and I'd recommend making a back up of the stock ROM before proceeding any further. Then flash the ROM and then immediately after flash the gapps file
    08-12-2013 12:20 PM
  11. aandrew610's Avatar
    http://forum.xda-developers.com/show....php?t=2265618
    Should help a little
    08-12-2013 12:26 PM
  12. metle_geek's Avatar
    Dude download it directly to your phone
    08-12-2013 12:51 PM
  13. iHackPro's Avatar
    The OP said s/he wiped the phone completely, so they can't use it.
    08-12-2013 12:57 PM
  14. metle_geek's Avatar
    Ok looks like your in deeper than i thought ok what recovery are you running?
    08-12-2013 12:58 PM
  1. HTC One GPe 4.3 gamecih problem
    By Vlad Mitrofan in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-30-2013, 10:04 AM
  2. HTC voicemail and text help.
    By Viva Terlingua in forum HTC One M7
    Last Post: 08-12-2013, 02:32 PM
  3. Need help with rooting
    By AsapAvi in forum Samsung Galaxy SIII I9300
    Last Post: 08-12-2013, 11:56 AM
  4. Replies: 0
    Last Post: 08-12-2013, 11:11 AM
