I've had an Atrix 2 for a couple of years now so it's about time to upgrade. All of my contacts are saved to the phone instead of google. Is there an easy way to transfer all my contacts to google?
Sync the contacts with Google - that's the easiest and quickest solution in my opinion.Three options I can offer:
1. Export them to a vCard file, and then import them in your Google account.
2. Just use a google account to sync them.
3. Use a service like Memotoo.com.
Sent from my GT-I9505 using AC Forums mobile app
Menu > System Settings > Accounts > Google > Sync Contacts
Will that override the saved ones?
Sent from a SlimROM S3.
Saved contacts on the device?
Sent from my SPH-D710 using Tapatalk 2
Sorry, I meant override as in force Google backup to save them?
Op has contacts saved on the phone and wants those saved to Google. If he sync's it should just backup what's on the phone to Google.
Hey folks--if the OP has a bunch of Phone Contacts, I believe they can't easily be synced to Google, because they're part of a non-Google account (i.e., Phone). As MichaelBR mentioned above, the best bet may be to export them as a vcf file, then import that file into Gmail on your desktop/laptop. On my Razr Maxx, the steps would be:
1. Menu/Contacts to display, select "Phone."
2. Menu/Import & export/Export to storage.
3. A message pops up asking you if you want to save your contacts as /storage/sdcard1/00001.vcf
4. Once you've saved the file, then connect your phone to a computer or remove your SD card and insert it into your computer, and copy the .vcf file to your computer.
5. On your computer, open Gmail, go to Contacts, click the "More" button, then select Import and import your .vcf file.
6. Once all of the contacts are in Gmail, all you need to do is sync your phone with your Google account, and all of those phone contacts should now be Google contacts.
