Results 1 to 12 of 12
Like Tree5Likes
  • 1 Post By srkmagnus
  • 1 Post By Golfdriver97
  • 1 Post By B. Diddy
  • 2 Post By bjfowle
    bjfowle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default phone contacts
    I've had an Atrix 2 for a couple of years now so it's about time to upgrade. All of my contacts are saved to the phone instead of google. Is there an easy way to transfer all my contacts to google?
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: phone contacts
    Quote Originally Posted by bjfowle View Post
    Welcome to the forums!
    I think they would have to be done one by one. But I could very well be wrong. Clicking on the contact, then where it is stored should bring up the change in where you want it.
  3. #3
    MichaelBR's Avatar
    Posts
    Global Posts
    97 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Android 2.3.4 :-(
    Three options I can offer:
    1. Export them to a vCard file, and then import them in your Google account.
    2. Just use a google account to sync them.
    3. Use a service like Memotoo.com.
    Sent from my GT-I9505 using AC Forums mobile app
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,759 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by MichaelBR View Post
    Sync the contacts with Google - that's the easiest and quickest solution in my opinion.
    Menu > System Settings > Accounts > Google > Sync Contacts
    Golfdriver97 likes this.
  5. #5
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by srkmagnus View Post
    Will that override the saved ones?
    Sent from a SlimROM S3.
    srkmagnus likes this.
  6. #6
    srkmagnus's Avatar
    Posts
    Global Posts
    13,759 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by Golfdriver97 View Post
    Saved contacts on the device?
    Sent from my SPH-D710 using Tapatalk 2
  7. #7
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Sorry, I meant override as in force Google backup to save them?
  8. #8
    srkmagnus's Avatar
    Posts
    Global Posts
    13,759 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Op has contacts saved on the phone and wants those saved to Google. If he sync's it should just backup what's on the phone to Google.
  9. #9
    srkmagnus's Avatar
    Posts
    Global Posts
    13,759 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
  10. #10
    Posts
    Global Posts
    33,047 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    That is what I was wondering; if syncing would override the user setting of contacts going to phone storage.
  11. #11
    B. Diddy's Avatar
    Posts
    Global Posts
    77,765 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Hey folks--if the OP has a bunch of Phone Contacts, I believe they can't easily be synced to Google, because they're part of a non-Google account (i.e., Phone). As MichaelBR mentioned above, the best bet may be to export them as a vcf file, then import that file into Gmail on your desktop/laptop. On my Razr Maxx, the steps would be:
    1. Menu/Contacts to display, select "Phone."
    2. Menu/Import & export/Export to storage.
    3. A message pops up asking you if you want to save your contacts as /storage/sdcard1/00001.vcf
    4. Once you've saved the file, then connect your phone to a computer or remove your SD card and insert it into your computer, and copy the .vcf file to your computer.
    5. On your computer, open Gmail, go to Contacts, click the "More" button, then select Import and import your .vcf file.
    6. Once all of the contacts are in Gmail, all you need to do is sync your phone with your Google account, and all of those phone contacts should now be Google contacts.
  12. Thread Author  Thread Author    #12
    bjfowle's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by B. Diddy View Post
    Thanks this was helpful. I just e-mailed the vcf file to my gmail account and then imported the contacts.
    B. Diddy and srkmagnus like this.
  1. "Searching for service" - turning off cell phone part of S4
    By thunderbunder16 in forum Samsung Galaxy S4
    Last Post: 11-14-2013, 08:57 PM
  2. Should I Get This Phone Or Wait?
    By MaddSkillz in forum Google Nexus 4
    Last Post: 08-17-2013, 02:33 PM
  3. When buying a new phone does colour matter to you
    By realisticgirl in forum General Help and How To
    Last Post: 08-16-2013, 01:54 PM
  4. phone lag
    By angman619 in forum Samsung Galaxy S4
    Last Post: 08-12-2013, 09:14 PM
  5. Wheres the Dark Theme to this Phone?
    By koolx in forum LG Optimus G Pro
    Last Post: 08-12-2013, 02:37 PM
