I have a Droid HTC Incredible 2, and have had it for about a year and a half now. Yesterday I went to use my phone, as normal, and went to look at some photos in my gallery. Well, the screen told me to "Please insert an SD card." As far as I know, I've always had an SD card and have never removed the one in there, which I believe is 16 GB. I took out the mini SD, left it out for a bit, put it back in, same problem. I restarted the phone, took out the SIM card, did all the things one does when there is a little glitch in the phone. Nothing has worked so far -- when I want to take a picture, look at pictures, listen to music, etc., it tells me there is no SD card. In the settings menu, under the 'SD and phone storage' tab, it says my total space is 'Unavailable.' The option to 'Mount SD card' is gray and can't be clicked on.
So is my SD card shot? Are all my hundreds of pictures and music all gone forever? Can/will Verizon help me out with this? Can/will YOU help me out with this?
Thanks!
Thanks!
