1. Alex Toole's Avatar
    I have a Droid HTC Incredible 2, and have had it for about a year and a half now. Yesterday I went to use my phone, as normal, and went to look at some photos in my gallery. Well, the screen told me to "Please insert an SD card." As far as I know, I've always had an SD card and have never removed the one in there, which I believe is 16 GB. I took out the mini SD, left it out for a bit, put it back in, same problem. I restarted the phone, took out the SIM card, did all the things one does when there is a little glitch in the phone. Nothing has worked so far -- when I want to take a picture, look at pictures, listen to music, etc., it tells me there is no SD card. In the settings menu, under the 'SD and phone storage' tab, it says my total space is 'Unavailable.' The option to 'Mount SD card' is gray and can't be clicked on.
    So is my SD card shot? Are all my hundreds of pictures and music all gone forever? Can/will Verizon help me out with this? Can/will YOU help me out with this?
    Thanks!
    08-12-2013 10:07 PM
  2. B. Diddy's Avatar
    Can you access the data if you put the microSD into your desktop or laptop?
    08-12-2013 10:11 PM
  3. Alex Toole's Avatar
    Right, it's MicroSD, not miniSD.... I have a MacBook so I can't insert my Droid's MicroSD card unless I have an adapter, which I don't. So I haven't been able to try that approach yet
    08-13-2013 06:33 AM
  4. badblue1__'s Avatar
    This has also been happening to me over the past year. What i do ...turn off the phone take out the sd card then put it back in then turn phone back on.
    It may take more than one attempt at this but it has always worked for me.
    If it doesn't work after a few attempts, you will probably need a new card.
    08-13-2013 10:27 AM
  1. Favorite settings widget help
    By enduser2941 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-22-2014, 07:40 PM
  2. IrLED? Help
    By atq123 in forum Samsung Galaxy Note 10.1
    Last Post: 08-13-2013, 11:23 PM
  3. galler crashing and stopping please help ASAP
    By abdullah98 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-13-2013, 10:22 PM
  4. google play music app issue (read please)
    By Jeremy_Collinsworth in forum Samsung Galaxy S3
    Last Post: 08-13-2013, 06:36 PM
  5. Backing up an Android
    By vpblaze in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-13-2013, 11:56 AM
