Results 1 to 6 of 6
Like Tree1Likes
  • 2 Post By srkmagnus
  • 1 Post By EvilMonkey
  • 1 Post By STARGATE
    Default Emerson 543 tablet power button problem...
    Hi all,so i have a emerson 543 tablet(basically the polariod PMID4311,rebranded)and i love it to be honest..nice little tablet for the price,but put it away the other day and the power button is now sunk in.,cant seem to get it out,anyone have this same problem?found a way of getting it out?know how to?my sons use it so all thair saved games will be gone if i cant fix it...hopefully someone can help.thanks in advance..
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Emerson 543 tablet power button problem...
    Quote Originally Posted by stermon View Post
    Hi all,so i have a emerson 543 tablet(basically the polariod PMID4311,rebranded)and i love it to be honest..nice little tablet for the price,but put it away the other day and the power button is now sunk in.,cant seem to get it out,anyone have this same problem?found a way of getting it out?know how to?my sons use it so all thair saved games will be gone if i cant fix it...hopefully someone can help.thanks in advance..http://imageshack.us/scaled/modthumb/94/fidu.jpg
    With the button sunk down you don't have the ability to still use it, right? You might need to remove the case (not sure how it's done on this device) and see what is wrong with the button hardware.
    B. Diddy and stermon like this.
  3. #3
    I'm not familiar with that tablet either. Might be able to take the case off (as suggested).
    Can you pop it out with a pin or something?
    stermon likes this.
  4. #4
    STARGATE's Avatar
    Posts
    Global Posts
    9,228 Global Posts
    Carrier
    None
    My cousin has a small Android tablet (don't remember the name or brand) and he had a similar problem.
    I yanked the power button up with a small knife, placed a piece of rubber under and then the power button back in place.
    His tablet has had no problems since then.
    If you try this though, be very careful!
    A knife is a dangerous tool and could hurt you or anybody around you at that moment.
    Sent From a Galaxy S4 Away!
    stermon likes this.
    Quote Originally Posted by srkmagnus View Post
    yes but you cant put it in sleep mode,so battery dies real quick..gona have to try and open it i guess,thanks for the advice tho..
    Quote Originally Posted by EvilMonkey View Post
    I'm not familiar with that tablet either. Might be able to take the case off (as suggested).no screws tho...so dont know...maybe pries it off i guess
    tried small flathead,but it just see saws backwards and forwards...really wierd..
    Quote Originally Posted by STARGATE View Post
    will try that if i can get button out,dont want to break the thing all together tho..cos all their saved games are on there,how would i copy the saved games over? if i can that is, to another android tablet?that would prolly work....
  6. #6
    Red face Re: Emerson 543 tablet power button problem...
  1. Capacitive buttons don't turn off
    By palanilopez12 in forum HTC One M7
    Last Post: 10-22-2013, 09:38 AM
  2. Power from TV/receiver/cable box USB port safe long term?
    By goelz83 in forum Google Chromecast
    Last Post: 08-14-2013, 12:21 PM
  3. multi-button (as in more than 12) mouse support
    By drunkscientist in forum General Help and How To
    Last Post: 08-09-2013, 02:40 PM
  4. Volume buttons no longer work.
    By jc0187 in forum Google Nexus 4
    Last Post: 08-09-2013, 12:33 AM
  5. Power Save Off not dimming display
    By Son Nguyen in forum HTC One M7
    Last Post: 08-09-2013, 12:23 AM
