Help! Just downloaded GO Launcher and loving it but....
welsby229
I can not get the fbwidget to work it is saying "failed to receive access token" i am unsure what this mean please help me fix!
Also when i get a text message i get notified twice once by Go Sms and once by "old" set up / launcher,
I have never used a launcher before and am very new to how it all works, Can anyone please help with these issues
Thank you so much!
I have a SGS2
Thank you so much!
I have a SGS2
Welcome to the forums!
You have a choice. You can uninstall the SMS add on from GO, or you can disable notifications from your stock messenger. Here is how: http://forums.androidcentral.com/sa...ng-apps-galaxy-s3-tab-2-no-root-required.html
r3dpuk3
