Hello,
What did I done?
I changed my sd card of my android to ntfs (ntfs is for you can put higher stuff then 4 GB on the sd card ,I needed that ,don't ask why ,I just needed a big file)
What's the problem?
when I done it, I found out I couldn't use my phone anymore on my pc (so I can see my stuff inside it) and I also found out I couldn't use the sd card on my phone aswell...
My phone
Samsung Galaxy S plus I9001
Custom rom Cyanogenmod 9
Rooted
What I ask
Is there any way to get my sd card back to Fat ,without getting my sd card out of my phone (I mean like ,it's inside the phone ,it's not a external ,I don't wanne break my phone)
I hope you can help me!
What did I done?
What's the problem?
My phone
Rooted
What I ask
