1. Jason Kerr's Avatar
    So i bought a samsung Micro Usb to Hdmi or MHL adapter that was supposed to work for the Galaxy s4. I plugged everything in to my 42inch Vizio and I couldn't see a picture. I wanted to know if anyone has been able to connect their Galaxy s4 with their Vizio tv's using an MHL adapter and not the internet.
    08-16-2013 05:05 AM
  2. Greg C's Avatar
    Here's a how to:
    How to Connect Your Samsung Galaxy S 4 to Your TV | PCMag.com
    08-16-2013 05:12 AM
  3. Edgarcalifornia's Avatar
    I have the same problem. I used the 5 to 11 pin adapter from Ebay with my Sprint Galaxy S4 and didn't work on my Vizio 47 TV. Then I used the red Y cable also on Ebay that they said it supposed to work, the one that connects to the usb port on the TV and still nothing.
    I've been reading a lot of forums. I found one that has a list of MHL Compatible TVs and Vizio is not on the list.
    The weird thing is that like 2 times, the phone did mirror on my TV but when I disconnected it, it didn't work anymore.
    Please help. I need to know if anyone has tried the OEM Samsung MHL 2.0 adapter on a Vizio TV?
    11-07-2013 02:02 AM
  4. jkrod's Avatar
    I have a Vizio 55 inch razor led smart tv. I went to TV settings went to cec settings and turned the cec function on and for some reason it only seemed to work with my hdmi plugged into the hdmi side, next went to input and clicked on mhl and it mirrors my galaxy s4 (unrooted). If it doesn't work you might have to restart you phone while plugged in like you are going to be using it I had to mess with mine for a few minutes before I figured out how to get it to work.
    03-03-2014 06:15 AM
  5. Mikex Rules's Avatar
    I called vizio and they said none of there tvs new or old r compatible with any mhl cables or adapters.. idk if its true and looking for hlp to hook mine up
    06-05-2014 05:33 PM
  6. Mikex Rules's Avatar
    is there anyone that knows any loop holes or any way to get mhl cable to work on a vizio tv.. I found 1 person that said his would only work if he used xbmc app
    06-05-2014 05:36 PM
  1. any way to mimic bottom 3 buttons on screen?
    By pjoseph in forum Samsung Galaxy S4
    Last Post: 09-09-2013, 04:45 PM
  2. My Galaxy s4 Pics
    By 303kush in forum Samsung Galaxy S4
    Last Post: 09-01-2013, 12:45 AM
  3. Apps not really moving to sd
    By DuStU in forum Samsung Galaxy S4
    Last Post: 08-16-2013, 09:38 PM
  4. New to Android Central... Samsung Galaxy Note 10.1 Questions
    By Saajan Patel1 in forum Samsung Galaxy Note 10.1
    Last Post: 08-16-2013, 12:39 PM
  5. wifi file transfer, PC to N4 & viceversa, options?
    By Charapa in forum Google Nexus 4
    Last Post: 08-16-2013, 10:25 AM
