I deleted (accidentally) some system files, and then nothing happened, but i hit the restore or backup from setting and it went fine untill the loading screen, i mean it shut down then the first loading image fine and the next one doesent load my system.. What can i do? (I think i know what software i shouldnt have deleted, if that could be of help)
Willl it cost much money if i take it for repair?
