I have a problem viewing certain files from a website on my captivate when I select the option from the drop down it wants to save the file with the extension .do which is a valid extension but when I do the same thing on my desktop computer it opens that file in the pdf viewer built into the browser. So the problem is on the phone im not able to view these files which I need to I have even tried saving the file as .pdf but will not open.
Here is the site if you want to take a look and try it on your phone and your computer replicate the issue.
http://www.poolnetstatistics.com/TAP/displayStandings.do?methodID=selectStandings
How can I get this to work ??
