1. rpshep's Avatar
    Most of the time, my phone is fine. But once every couple days, it randomly freezes. The screen will be off, and I'll go to check something, but it won't come on. I know it's still on because the notification light will still be blinking. My only option to get it back on is to turn it off completely and turn it back on or to remove the battery and turn it back on. Any help would be greatly appreciated.
    Samsung Galaxy Ring (SPH-M840)
    Android 4.1.2
    Virgin Mobile (US)
    08-26-2013 07:02 AM
  2. Golfdriver97's Avatar
    Android 4.1.2
    Virgin Mobile (US)
    Welcome to the forums!
    Have you tried rebooting into recovery and clearing the phone's cache?
    08-26-2013 09:22 AM
  3. rpshep's Avatar
    Thanks for your reply. No, I haven't. How would I go about doing that?
    08-26-2013 10:26 AM
  4. Golfdriver97's Avatar
    Try power off, and to reboot, hold power and volume up and release when you see Samsung title.
    From a SlimROM S3
    08-26-2013 11:17 AM
  5. rpshep's Avatar
    Thanks so much for your help. I just tried that. We'll see if it works!
    08-26-2013 11:36 AM
  6. Golfdriver97's Avatar
    When you get in you want to go to wipe cache partition. Volume button to navigate and power or home to accept.
    From a SlimROM S3
    08-26-2013 11:45 AM
  7. gaoshoualauj's Avatar
    Hi I'm having the same issue on my phone too. Some how it's not working, it keeps freezing and when i go to my contact or other apps it keeps saying "unfortunately Google Play has stop" and "Unfortunately your media has stop" I have try re boosting, and also my sound don't work. When I call it does not ring or dialing. There is no voice sound. Some time there will be sounds but that only some time when i have my headset on that only how can call, other then that it does not work. Can some one please help me. I got this phone not too long ago. Or should I just get a new phone?
    02-17-2014 09:45 PM
  8. derele james's Avatar
    Will this Samsung galaxy ring have an update anytime soon?
    02-19-2014 10:45 AM
  9. Thwaaarted's Avatar
    I was desperate to get my phone running again after a "deep freeze"...thanks so much for the free advice; it's worked like a charm!
    02-21-2014 08:39 AM
  10. cmarmolejos236's Avatar
    I have the same issue. Did it work for you??
    04-18-2014 12:30 AM
  1. Interesting Or Ugly Cartoon plush Power bank for Galaxy?
    By teribithia in forum Samsung Galaxy S III Accessories
    Last Post: 09-17-2013, 02:32 AM
  2. Replies: 1
    Last Post: 08-31-2013, 09:20 AM
  3. Samsung Galaxy S3 not connecting with PC (UK)
    By phynbarr in forum Samsung Galaxy S3
    Last Post: 08-26-2013, 10:04 PM
  4. Samsung Galaxy S3
    By Sneha Lance in forum Android Apps
    Last Post: 08-26-2013, 09:31 AM
  5. Oppo Find 5 lockscreen on Galaxy S4?
    By StephenPerr in forum General Help and How To
    Last Post: 08-25-2013, 10:47 PM
