Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By srkmagnus
    Default Galaxy s4 not recognized through usb (mac)
    i was hoping someone has found a solution to this issue. when i plug my phone into my mac at work, the computer doesn't recognize the phone and the phone doesn't recognize that it's been plugged into a computer. it starts charging but no alert about being plugged in by usb, and i can't gain access to options like choosing ptp or mtp. on the mac, android file transfer just says "no device found" as if nothing were plugged in. any advice would be greatly appreciated.
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: galaxy s4 not recognized through usb (mac)
    Quote Originally Posted by geoffropuff View Post
    Take a look at this: Android.com
    If work allows you to install that application onto the Machine you should be able to access the device.
    thanks, but maybe you didn't see in my block of text that i am using android file transfer. when i plug my phone in, it acts as if there's nothing plugged in, as the message "no device found" is shown whether or not my phone is connected. any more advice considering that i am using the software? it worked fine before with my old galaxy nexus.
    the problem was solved with a different cable. not sure why but i'll take it.
  5. #5
    Where did you get the new cable? Did you have to go back to the ATT store? I've been all over several forums to no luck.
  6. #6
    liddellw1's Avatar
    Posts
    Carrier
    AOKP ICS
    Why not use Airdroid and transfer without cables?
  7. #7
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Quote Originally Posted by Amy Felix-Reese View Post
    If you have an extra cable around try that. Otherwise, any retailer an help you with that. :-)
    Sent from my GT-P7510 using AC Forums mobile app
    Golfdriver97 likes this.
  8. #8
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,673 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    You can also check out cables here at ShopAndroid.
    Sent from a Slim 4.3 S3
  9. #9
    Seems like this algorithm helped me:
    1. Install latest version of Kies
    2. Restart iMac
    3. Try to unplug cable both from iMac and from your Galaxy S IV
    4. Try to restart Eclipse (if you use your device for coding in Eclipse for Mac, as I do)
    The problem was not in the cable in my case.
  10. #10
    As soon as I used another USB-3 cable it was recognized and all is well!!!!!
  1. Verizon Samsung Galaxy Note 2 (White) w/ extras
    By galpdawg in forum Marketplace Archive
    Last Post: 09-16-2013, 07:08 PM
  2. Seeing the Unread mail folder on my Samsung Galaxy S4 4.2.2
    By Jakkov in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 09-03-2013, 04:08 PM
  3. Replies: 9
    Last Post: 08-27-2013, 02:17 PM
  4. Wifi not showing
    By chirag05 in forum Samsung Galaxy Grand
    Last Post: 08-27-2013, 12:37 PM
  5. Turn off unread email account Galaxy S4 email icon
    By Sven Johannsen in forum AT&T Samsung Galaxy S4
    Last Post: 08-26-2013, 01:02 PM
